Does Ventuz 4 support image sequence?
Hi, an urgent question, does Ventuz 4 support image sequence? because i can't find the feature anywhere..
Re: Does Ventuz 4 support image sequence?
the image sequence no longer exists, and the funtionality has been moved to the Movie Frame node (works the same way, is much more performant). However, there is a bug we just noticed with that and are currently fixing.
For urgent cases, just open V3, save an archive with just the image sequence node and import that into V4, it will work. The performance of the new implementation in V4 is far better, so do use the movie frame node as soon as it is fixed.
-E
-E
this is fixed in v 4.01, which is available for download.
