Hi all,
have some problems with the runtime of V4.
I can´t end the runtime with <ESC>, have to use the Taskbar (on second screen), right click, End.
When installing V4 next to V3, and uninstall it again later, there is no more >Configure< in the context menu of a .vpr.
Configuring a .vpr in V4, I miss things like "virtual fullscreen" and "show pointer" checkboxes, as well as the posibility to choose an adapter.
And what I miss is a search, within the local help (for instance called from the "Ventuz User Manual" link on the bottom of the Render Setup window.
Tom
Runtime issues
Re: Runtime issues
Hi There,
Virtual Fullscreen and ShowMouse Pointer options can be found in the new Ventuz Configration Editor --> Audio Video Config if you have a DirectX output.
I added tickets to our internal wiki for the other issues. The missing Configure entry workaround would be a shortcut of the Presenter.exe with the "-override" commandline option.
Daniel
Daniel
Re: Runtime issues
Hi Daniel, thanks for your answer!
More clicks than in V3 and as far as I understand the configuration I choose will be valid for the system.
So different .vpr´s can´t have a different configuration at the same time?
Tom
I took a look there but didn´t found the options under that little triangel before...Virtual Fullscreen and ShowMouse Pointer options
Tom
Re: Runtime issues
Yes there is only one confugration at the same time. but you can switch the configuration manual or remote via the Ventuz Machine Service or access them via the Live Options.
