today I tried to use Volume Textures with Ventuz. I created a Volume Map with transparency in the DirectX Texture Tool and imported this DDS Texture in Ventuz. I connected it with a 3D-Mapping Node and changed the MappingMode to 4D. I used a Cube as Geometry. But it didnt use the "slices" saved in the Volume Map. It just projected on the outer sides of the Cube, just like a 2D-Texture would. It was also not possible to show just a certain slice. How can I use Volume Textures in Venutz properly? And what would be possible applications?
Volume Texture Problem
Re: Volume Texture Problem
currently you can use Volume Texture only with HLSL Shaders; check out the attached scene.
- electricity_1.vza
- (1.13 MiB) Downloaded 473 times
