Binding Keyframe Values to XML File?
Hi, I am just learning Ventuz, and I would like to bind the value of a keyframe to an external data source, like an xml file. I don't see the same options with the Keyframe Node's Value property as I do with other nodes. Thanks!
Re: Binding Keyframe Values to XML File?
Hey there welcome to the Ventuz forum
Unfortunately there is no way to bind a keyframe value. If you want to do so you need to animate with the interpolation nodes i.e the Linear Node.
Cheers!
Cheers!
Hi everyone...............................
i wish to make a custom node with functions like the GT_Particle_Lite pack can anyone tell me how to make a custom node in ventuz with my own custom defined functions.......
It is quite simple. You need a Container node. There are two nodes. A Hierarchy Container which can be used in the scene hierarchy like any other Hierarchy node and the Content Container node which can only be used in the Content Editor. Most of the time you will use a Hierarchy Container node so let's use this one as an example.
Add a Hierarchy Container node to your scene
Double Click the left side of the node on the small rectangle to "enter" the container
Add an Axis node to the Hierarchy inside this Container. Delete the Output node. (You would need this node if you want to place any node after the Container node later on.)
Expose the PositionX property by double clicking on the small square left of the property in the Property Editor. It will turn green. This will pass the property up to the Container. The Expose Attributes dialog opens automatically. Uncheck the Inherit flag for the Name and change the name from PositionX to MyProperty. Press OK.
Open the RightMouseButton Context Menu of the Node and select Icon->Expose
Now leave the Container by double clicking the left arrow at the top left of the Container.
Your Container node now has the icon of the Axis and one property called MyProperty.
You can seal the Container using the RightMouseButton Context Menu to block third party access to the node. If you do so, your node will look and behave liek any other Ventuz node.
You can put ANYTHING in a Container, even complex scenes. You can create custom properties, icons and so forth. Read the manual for more information about Containers and Exposing.
