Hi all,
I would like to know what's the maximum texture resolution supported by Ventuz
Max resolution for video
Max number of polygons. Can I fill 6GB of vram?
Regarding Ventuz 4 every gpu will handle its own memory?
Maximum
Re: Maximum
texture res.: domt know but if you run into problems you can splitt the texture into slices
movie size: dont think, that your workstation can play max texture size smoothly..but dont know spec max
poly count: limitation ist not your memory...limitation wil be again the power of your workstation
Re: Maximum
The max. possible texture resolution in Ventuz 3 x64 on moderns GPU with appropriate amount of memory is 16k x 16k.
