I'm relatively inexperinced with Ventuz and would really appreciate some help.
I have several sets of content, all currently within one scene (lets call them A,B,C and D) that I want to apply to opposite faces of a Cube (side 1 and side 2) when the operator calls for them. So, for example, content A is visible on side 1, the user hits a key to call D next, the cube rotates 180 and D is on side 2. The user the calls for content B, the cube rotates 180, and B is on side 2.
I'm sure this is very straightforward when you know how, but I want to make sure i do it in the most efficient way. Any guidance gratefully received!
Many thanks,
Paul
Mapping content to cube faces
Lukasz_stryjek
Re: Mapping content to cube faces
I think it can be done easily by constructing the cube by hand from 6 planes with different texture on each. You can get different content vision by rendering 6 render targets and using them as textures.
As for cube rotation I think it can be done with value switch node.
If those nodes are new for you just hover your mouse over them in toolkit and hit F1. Then choose interactive example.
Good luck.
Good luck.
6 planes is definitely the easiest for this. As for the rotation... have a look at this tutorial in the help files:
http://www.ventuz.com/support/help/late ... Logic.html
that might be of help?
hi all
as a little carneval present...try this
it is done without any keyframe animation and its using 6 planes! the big advantage is: it is working even if the animation is not completed!
so don't forget the power of a counter in combination with a damper!
greetz and helau
chriss
greetz and helau
chriss
- cubeAnimation.vza
- (788.69 KiB) Downloaded 634 times
.......do you like my carneval costume?
chriss
chriss
Hi Chriss, very nice, thanks.
I try to avoid keyframe-anims wherever possible, math-nodes mostly do a far better (and leaner) job(*). Added benefit: no unclear states.
If I may add a suggestion: use an Oscillator instead of a Damper (see attachment). The "wobbling" IMO gives you a much more organic and natural looking movement (that would be a total bitch to create with Keyframe-Anims). Only drawback: Osci-nodes are a bit harder to time, since the duration is not absolute but depends on frequency & damping... usually take some time to get it "just right".
squiggle
(*) I very often use a chain like this: Bool-Node (for the state) ---> Clipping-Node (translates 0/1 to the correct range) ---> Oscillator or Damper (for the transition/animation).
squiggle
hi squiggle
yes...the osci instead of the damper is another option
thx and greetz
chriss
thx and greetz
chriss
spikylaura
Many thanks for all your replies - I didn't have reply notification turned on, hence the slow reply.
I should have been clearer in my original post - the cube I'm trying to map onto has rounded edges, so constructing it out of 6 rectangles is not an option. I have ended up creating a Case Switch for each side and a friend is writing a script to control what content is showing on which side, so hopefully problem solved.
Many thanks again
Paul
Many thanks again
Paul
