C#
Posted: 17 May 2013, 21:00
by gabrielefx
I love Ventuz...that's why I purchased it.
but I don't understand what is possible to do with the C# node....because I don't know anything about C programming.
I would like to understand what are the possibilities of this node.
Could you explain some possibilities? Some examples? Is it fundamental?
I watched a video of a Russian company that develops games with Ventuz. Are they developed using the C# node?
Why use the C# node within Ventuz?
This is the dark side of Ventuz....
Re: C#
Posted: 18 May 2013, 13:10
by gabrielefx
I've purchased this course:
http://www.infiniteskills.com/training/ ... sharp.html
I hope it will explain more
In the meanwhile I think that the old Toolbox scenes are simpler to understand. You added to many nodes in the latest help version that render the structure more complex.
Re: C#
Posted: 20 May 2013, 08:20
by TobiTobsen
gabrielefx wrote:Hi,
Learning some c sharp basics first and than try some logics inside the ventuz node seems to be a smart way.
The node is very helpful for some complex algorithms. Furthermore more you can address functions that are not available in ventuz directly. What I also like a lot is that it is easier to organise and keep the written code well sorted especially if you work in a team.
You can edit your post by pressing the 'edit' button that is shown on the upper right corner of your post.
Tobi
Re: C#
Posted: 20 May 2013, 14:33
by Chris
A lot of people use scripting for a lot of different things in Ventuz, basically Its data in/data out.....it would take too long to explain what is possible :))) you'll know what i mean when you start ;)) In my experience so far its def worth looking at, its like having an extra arm ;)
Here's one we were chatting about previously......sending emails from within a scene ;)
http://forum.ventuz.com/viewtopic.php?f=11&t=2762
A good one to get your imagination going ;)
p.s It looks crazy to start with!!......but persevere ;)
chris
Re: C#
Posted: 21 May 2013, 14:48
by ErikB
Another very useful thing is that it allows you to tie in external libraries that can be registered to the windows GAC. An example for this would be the LeapMotion I mentioned in another post.
So, they publish the C# libraries, I add them to my windows, then I can address, read and talk to the LeapMotion directly from my C# Script node. So when you do a gesture, their library sends a signal and I output that as an event in Ventuz. If you start looking around, essentially it means you can tie anything into Ventuz and Ventuz into anything.
