I love Ventuz...that's why I purchased it.
but I don't understand what is possible to do with the C# node....because I don't know anything about C programming.
I would like to understand what are the possibilities of this node.
Could you explain some possibilities? Some examples? Is it fundamental?
I watched a video of a Russian company that develops games with Ventuz. Are they developed using the C# node?
Why use the C# node within Ventuz?
This is the dark side of Ventuz....
C#
Re: C#
I've purchased this course:
http://www.infiniteskills.com/training/ ... sharp.html
I hope it will explain more
In the meanwhile I think that the old Toolbox scenes are simpler to understand. You added to many nodes in the latest help version that render the structure more complex.
Re: C#
Learning some c sharp basics first and than try some logics inside the ventuz node seems to be a smart way.gabrielefx wrote:Hi,
The node is very helpful for some complex algorithms. Furthermore more you can address functions that are not available in ventuz directly. What I also like a lot is that it is easier to organise and keep the written code well sorted especially if you work in a team.
You can edit your post by pressing the 'edit' button that is shown on the upper right corner of your post.
Tobi
http://www.radar-touch.com
http://www.prime-touch.com
Re: C#
A lot of people use scripting for a lot of different things in Ventuz, basically Its data in/data out.....it would take too long to explain what is possible
)) you'll know what i mean when you start
) In my experience so far its def worth looking at, its like having an extra arm
Here's one we were chatting about previously......sending emails from within a scene
http://forum.ventuz.com/viewtopic.php?f=11&t=2762
A good one to get your imagination going
p.s It looks crazy to start with!!......but persevere
chris
chris
Re: C#
Another very useful thing is that it allows you to tie in external libraries that can be registered to the windows GAC. An example for this would be the LeapMotion I mentioned in another post.
So, they publish the C# libraries, I add them to my windows, then I can address, read and talk to the LeapMotion directly from my C# Script node. So when you do a gesture, their library sends a signal and I output that as an event in Ventuz. If you start looking around, essentially it means you can tie anything into Ventuz and Ventuz into anything.
