hi to everyone,
how can I use the method of a node which is not marked by a lightning sign.
For example , the touch Translation node, I want do something when the TouchPressed method is fired.I want use it to fire other things .
Have you met somethings like this ? and how do you solve this kind of problem .
tell me what you do ,share your experience with me. I am grateful for you .
thank you all the same.
how can I use the method not marked by the lightting mark?
Re: how can I use the method not marked by the lightting mar
The TouchPressed is a Boolean type output which means it will give either a 'True' or 'False' output when the fired. So you need to connect it to the property of another node that will except this type of input. (drag the node input property onto the Touch node and select TouchPressed
i.e. 'Bool' variable, several of the 'Math Effects' etc etc....
Quick tip....In the top right hand corner of the In/Out window you will see a magnifying glass click this to see realtime activity in the In/Out window
always handy
chris
chris
