Hello everybody!
I need to use 5 different audio outputs, is it possible to install several sound cards in server to use separate audio channels in ventuz?
Several sound cards
Re: Several sound cards
havnt tried that, but i allready used rme and motu soundkarts with more than 1 stereo output. but it should be possible to use more than just one soundcard in a system
take care, that you need soundcards with wdm drivers! test everything before you buy!
Thank you very much! And what about rme and motu soundcards, how many outputs can they give?
the ones i have used had 4 stereo outputs. but take care: in ventuz you have always stereo outputs!
Another workaround is using a dts-wav which you can import into Ventuz.
Google for Minnetonka Surcode DTS.
This software produces dts-wav's containing 5 compressed (lower compression than ac3) channels + one for subwoofer.
Soundquality is excellent.
Output this stream through digital-out of your soundcard.
For playback you need a cheap homecinema-system with DTS-Decoder.
many greets,
Stephan
many greets,
Stephan
And to answer the original question, yes it is possible to install several soundcards. They can be addressed in Ventuz as the different ordinals in the audio output properties. I believe Windows can handle up to 8 outputs - but I am not sure on that number.
Thnx u all! We have an interesting project, if everything is ok (hope so) I'll write a few words about it here.
