MICABIM
Post
by MICABIM » 28 Feb 2013, 19:43
I make a presentation, but I want used it on my iPad to show it.
I need buy any app to do this or only a function on ventuz.
Monica
Oliver
Post
by Oliver » 01 Mar 2013, 11:44
Yes and no.
http://live.stereolize.com/2012/10/18/2 ... -ipad.html
Ventuz runs only on Windows based systems.
There are workarounds but probably none that u will like.
I actually i dont know if it is possible to boot an I-Pad with e.g. windows mobile.
Stereolize realized it with a kind of a remote desktop solution - but this is - in my experience- often laggy...
Post
by Christian Krix Schmidt » 01 Mar 2013, 12:11
Ventuz will never run in any decent or usable way on current iPads. Like Oliver wrote, it's WIndows only. Which means in turn however that you can run it on any full WIndows 8 tablet (even Windows 7). No Windows RT however. There are quite a lot of tablets with the full version of Windows 8 available. Get one with an i3 or i5 processor not an Atom one. Those are a bit too slow and you can run Ventuz on it. We recently did an entire Ventuz application running on a Samsung Windows tablet. They have Intel 3000 or Intel 4000 graphics chips and can run Ventuz. You cannot do too much and have to optimize a bit but you can actually create decent presentations - even with 3D animations that you would otherwise have to program to make possible on an iPad. So my advise would be to drop the iPad and just go with a WIndows tablet.
Oliver
Post
by Oliver » 04 Mar 2013, 14:55
Christian Krix Schmidt wrote: So my advise would be to drop the iPad and just go with a WIndows tablet.
which I personally think is generally the best way
Post
by Christian Krix Schmidt » 06 Mar 2013, 13:06
In a single setup probably. But on an event with dozends of WiFi networks active and several clients streaming content at the same time such solutions tend to be unreliable and sluggish. Maybe in a few years when the network technology has further improved or highly professional equipment becomes more affordable it is a choice. I wouldn't do it.
mortoni
Post
by mortoni » 07 Mar 2013, 09:58
We've used splashtop quite a bit with no problems, but we generally need a different interface shown on the iPad. We just build a web front end for that. There are several methods to connect to the main scene. Having a Windows tablet just makes it easier because Ventuz runs on client and main machines.
dondi
Post
by dondi » 08 Mar 2013, 22:14
While Erik was visiting here on Monday, we installed Ventuz on my Microsoft Surface Pro device and it works very nicely!!!!!!
alfred
Post
by alfred » 11 Mar 2013, 15:24
if the presentation has some 3D models or 3D effect, is it possible for it running smoothly on a windows based tablet, like surface?
alfred
dondi
Post
by dondi » 11 Mar 2013, 16:14
@Alfred I cannot answer that question definitively as I have no working experience with Ventuz (yet). We are just starting to dip our toes into the proverbial waters. If there is a Ventuz project or tutorial that came with Ventuz that could be used as a baseline to answer your question, I would be more than happy to open it and give you feedback
