Shader and Renderer
mofo7777
Shader and Renderer
Post by mofo7777 » 14 Feb 2013, 14:38
Hello.
There's some strange behaviour in the renderer when using shader.
For exemple i've got a texture with UV wrap, if i set the statistics display, the texture UV becomes clamp...
So my question : what are the bests practices with shader to interact correctly with the renderer. the RTFM did not help for this.
Best regards.
mofo7777
Re: Shader and Renderer
Post by mofo7777 » 14 Feb 2013, 19:10
Ok i found the problem.
When the statistics are off, the renderer uses the AddressU and AdressV from the shader. When the statistics are on, the renderer uses the AddressU and AdressV from the texture node.
So it seems that the renderer ignores shader texture properties when the statistics are on. Perhaps it depends of the shader contents.
Post by Karol » 19 Feb 2013, 09:46
Hi!
Could you nevertheless post an example anyway, please!?
mofo7777
Post by mofo7777 » 19 Feb 2013, 19:39
Hello
BugTextureShader.vza
the sample
(657.42 KiB) Downloaded 455 times
