I'm a student from Malaysia, I meet two simple but weird question in Ventuz 3, I try to use Ventuz to create an interactive installation for my final project about Topshop, and the problem is, inside my every interactive interface got at least one different look button inside, but after i click on the button, it should shove off with the interface, but it still stay on where it is, may I know how to make it move away and the next button move in like the interface?
Another problem is, I know Ventuz can go next and next slide in one way, but how if I want create a button inside and make it could jump from Slide No.1 to Slide No.3 and skip the Slide No.3? Will it possible?
thanks !
"Moving button" & "Jump/skip slide"
Re: "Moving button" & "Jump/skip slide"
If you just want to jump from slide to slide, each slide container has a JumpPresent or JumpBegin method.
I'm sorry but I didn't get your question with the interfacing movement could you please describe your probleme more in detail.
Cheers!
Cheers!
