hi,all
When i run VPR file, is there another method to close the program without using mouse or keyboard (ESC or ALT + F4)?Is there a method to close the program node inside ventuz? so that i can create a 'Close' button for that.
thanks.
'Close' button ?
partyboarder
Re: 'Close' button ?
The emitSimulatesHardware Method does not release the Alt-Key after exit. So Windows still thinks that the key is still pressed. You have to manually press it again to regain normal control.
cheers
cheers
