there seems to be some strange behaviour when editing Expose settings.
When I edit my Expose Attributes (Right-click on property -> Expose -> Edit...) the window ALWAYS displays the last edited Expose Attributes.
When I open the Attributes a second time the right values are displayed.
I'm currently on Ventuz Touch 3.08
Is there a solution for this?
Greetings
Hendrik
Wrong Parameters in "Edit Expose Parameters"
Re: Wrong Parameters in "Edit Expose Parameters"
Thanks for your report.
This is a known issue but the dev team cannot reproduce the behavior. Can you repoduce it?
Cherio!
Cherio!
I'll try tomorrow to exactly reproduce this behaviour...
Until now it seems that this only happens while you EDIT previously exposed properties with custom names located in a Container
Hendrik
Hendrik
Hey there!
I could reproduce this strange behaviour.
I created a new Project and created a Hierarchy Container. I put an Axis, a Material and a cube inside and exposed some Properties of the Axis and renamed them.
As soon as I edit one the names of the exposed Properties, the next Property Attribute Window will show the last edited Values. This happens every time I edit a property`s name.
I hope this helps the Dev Team to fix this problem.
Cheers!
Cheers!
