can anybody help in returning back the values of the keyframe and the position in the animation editor??
once i click on the K.frame it should show directly these values,,,but for some reason it is not,,unless i double click each time to see them!! and it is a waste of time to do so,,should be seen on spot once i click on the k frame.
i tried to re-install the prgm, but with no use!!
thankss,
Hot to re-show the values of a K.frame,,its gone!!
Re: Hot to re-show the values of a K.frame,,its gone!!
the values are shown when the red line is above the keyframe or if you doubleklick the statemark at the topline.
cheers!
cheers!
Noorslm1
Hi Oliver,,
thx for following up,,but still,,, i cant see these values unless i d.click on the value it self (it's blank before) even with the red line ; even the states(S1, S2 , ..) arent seen also; i ddnt mention this also before; attached is a pic for better view;
Thnks in advance,, a lot
Hm - as i can tell from your screenshot you are using "internet explorer" i think thats why your system is messed up !
Just kidding
I can not reproduce this here. Usually when you single-click a keyframe the values should show up in those little windows.
I will take this into further investigation. Could you pls tell me on which platform you are working on?
System - V3 version etc.
Cheers!
Just kidding
Cheers!
Noorslm1
/Hi , , again
and apologetic for wasting your wasting your valued time,,
The platform if you meant about the OS it's Desktop Win 7 Enterprise ;
Dunno if i helped ,,
but thx anyway for your patience.
Cheers,,,
noor.
Cheers,,,
noor.
