Import 3D Objects with multiple UVs
GlareTechnologies
Post by GlareTechnologies » 21 Aug 2012, 11:23
i have tried to import .dae with 2 UV sets.
Somehow I only get the first UV coordinates in my HLSL Shader.
Attached to this post my (hand-made) collada file and the shader:
Is it generally possible to import 3d objects with multiple UVs ?
If yes, any idea whats wrong with my code or file ?
Bastian
float4x4 WorldViewProjection  : WORLDVIEWPROJECTION;
texture Texture0;
sampler Sampler0 : register (s[0]) = sampler_state
	Texture = <Texture0>;
texture Texture1;
sampler Sampler1 : register (s[1])  = sampler_state
	Texture = <Texture1>;
struct VS_INPUT
	float4 Position : POSITION;
	float2 UV0 		: TEXCOORD0;
	float2 UV1 		: TEXCOORD1;
struct VS_OUTPUT
VS_OUTPUT VS( VS_INPUT Input )
	VS_OUTPUT Output;
	Output.Position = mul(Input.Position, WorldViewProjection);
	Output.UV0 = Input.UV0;
	Output.UV1 = Input.UV1;
	return Output;
float4 PS( VS_OUTPUT Input ) : COLOR
	float4 c0 = tex2D(Sampler0, Input.UV0.xy);
	float4 c1 = tex2D(Sampler1, Input.UV1.xy);
	return c0+c1;
technique Tech1
	pass pass0
		vertexshader = compile vs_3_0 VS();
		pixelshader  = compile ps_3_0 PS();
object3.dae.zip
It is an uncompressed file. Just remove .zip.
(5.8 KiB) Downloaded 536 times
