Hi all,
This is probably one of those very simple things when you know how: I would like to rotate an object on one axis, and when 360 degrees is complete, reset the value to 0, but without the object spinning back.
Hope you can help.
Many thanks
Paul
Reset rotation value . . .
Re: Reset rotation value . . .
have you tried to use the modulo propertie?
Chris is right just take a float expression and make a modulo 360. The resulting expression would look like
A % 360
A % 360
spikylaura
Thanks for your quick replies. I'm unfamiliar with the Modulo property, so thanks for the heads up. I'll have a look today and let you now how I get on.
Many thanks,
Paul
Many thanks,
Paul
spikylaura
I have attached an example to illustrate what I'm trying to achieve. The object has 2 sides - A & B. There are 3 animation states - S1, S2 and S3. S1 shows side A at 0 deg, S2 shows side B at 180 deg S3 shows Side A again at 360 deg.
What I would like to happen is when the animation reaches S3, to effectively swap to S1, or 0 deg, without the object "rewinding' through 360 deg.
I'm not quite sure how to use the modulo function of the Math Effects, so I don't know if this will achieve what I'm trying to do.
Many thanks for any help you can offer.
Paul
Paul
TobiTobsen
what modulo does is that it returns the rest atfter dividing.
For a few programming languages a "%" is the sign for the modulo operation.
So lets say 180%360 returns 180.
540%360 returns again 180.
360%360 retrurns 0 as there is no rest.
I can not really see the flipping problem in you scene but i have attached a scene with a modulo expression.
Tobi
Tobi
- Rotation Example_Mod.vza
- (9.04 KiB) Downloaded 565 times
http://www.radar-touch.com
http://www.prime-touch.com
Stefan Goerke
it is possible to jump from one value to another by using the "jump" interpolation type in the diagram view of the animation editor.
see aso here:
http://www.ventuz.com/support/help/v3_0 ... ditor.html
Sometimes using the Mover node could be also an opportunity.
with best regards,
Stefan
see aso here:
with best regards,
Stefan
- endless rotation demo.vza
- (12.06 KiB) Downloaded 552 times
