hlsl code issues
hlsl code issues
if you press strg - a the hlsl node will deactivated instead of selecting the source code.
sometimes you sourcecode will reset to your last saved version if you dont click upload and switch the scene tab.
Re: hlsl code issues
the search function doesn't work
well - your open the scene search by pressing strg - f not the source search...
i thing no shortcuts working right now....
great
great
where can i download the previous release?
i like the part where the installer told me that i got a newer version allready installed and quit directly...
MEH!
						MEH!
If you want to install an older version, you have to un-install the newer version before!pyrrr wrote:i like the part where the installer told me that i got a newer version allready installed and quit directly...
MEH!
strg - s in the hlsl should automatic force an update in the viewport - that would be great!
mhh you are right this could be a problem - save the shader instead of the scene.  maybe a ctrl shift s or something equal. this would a immense increase for the workflow also in c# scripts!
little bit off topic:
a display modi for the script editor who shows in and outputs would be nice
in the sript editor you can only see the input- or output-variables. i want to see them both.
