dear ventuzians,
a nice hardware solution for converting midi-notes to relay-contacts is the MTC64 Midi to Contact Converter from http://www.doepfer.de/mtc.htm, it spends you up to 64 relay-contacts in conjunction with relayboards.
I know, also possible with cheap Arduino, but nowbody of you will spend extra time for programming extern hardware ...
The Doepfer-Interface is plug'n play.
Choose MIDI OUT, Channel 1, velocity 1, note 0 on/off = relay 1 on/off etc.
MTC64 motherboard ~ 100 Euro, each relayboard (16 relays) ~ 90 Euro.
Many greet,
stephan
MIDI-OUT to RELAY-CONTACTS
Re: MIDI-OUT to RELAY-CONTACTS
Nice, Thanks!
http://www.radar-touch.com
http://www.prime-touch.com
