hello,
i wrote a little script which is able to create uri like
file:///C:/VENTUZ/PROJECT/IMAGE_0001.DDS
if i plug this result into a dds loader i get results?
any ideas?
dds for animations
Re: dds for animations
nevermind - i found a solution. you can switch to all files and choose a dds sequence in the image sequence node. would be nice to add dds to the chosable filetypes.
If I got you right, you can easily do this without script - jsut by using the URL and DIR node.
cheers
cheers
