i created a litte c# script wo generates me an dynamic color.
if i link the color output of my script to the color value of my touch paint - the color seems to change but in the render view and by drawing i see no effect.
i attached the file below
Dynamic Color in Touch Paint
- mouse.rar
- (299.17 KiB) Downloaded 457 times
Re: Dynamic Color in Touch Paint
hi pyrrr
i can't open your scene because it is done in the ple version but i would think you just forget to set changed to true! i you don't do that ventuz doesn't "see" that you changed any output value!
- Script.vza
- (5.19 KiB) Downloaded 499 times
hey,
let me explain, the color value of my touch paint changes in the node view not in the render window.
hey
sorry....it was just a try to help...but i cant open your scene because ir is a ple scene...i dont have a ple installed!
and witout any info what you have done....hey...i cant help
hey pyrr,
First of all, chris is right, you just forgot to return true - to let Ventuz Validate and use the changes.
If u do it - your script works.
Notice that your script uses the z axis as well to generate values. As long as you use an input without a Z value (like Mouse or touchscreen or whatever) your Z never changes and your B(lue) vlaue will stay 0.
Also every horizontal movement will make the paint red and vertical will always be green.
Finally, for the demanded effect you can also easily split the color with the rgb to color node and add some movers to it. This will probably give you a much more beautiful effect.
And btw, chris - you can just request a PLE key and add it to your existing installation- so you can start both versions. (If needed
cheers
O
cheers
O
