Is there a way to access raw TUIO cursor postions in Ventuz?
Maybe through the OSC Input node? The first 1 or 2 cursors would be enough.
I could not get it working with address "/tuio/2Dcur" @ port 3333 and a 'set' string for output
I need this for the combination of a Paint node with some 'checkpoints' (which i would realize with cursor positions and HitTest node).
If I use an OSC bridge, either the external app can receive the TUIO data or Ventuz, whichever was started first.
As far as im informed about UDP, only 1 application can listen to a specific port.
If the TUIO device could stream to multiple ports it may work, but its driver does not give any options on that.
Any suggestions in this issue?
Thanks in advance!
