Hi Ryan!
You bound the File property of the Texture Loader to the internal loader of the Material node!
You have to bind the Texture output property of the Loader node to the Texture Property group of the Material node.
With your binding the Texture Loader loads async AND the Material node loads sync (as it cannot load async).
Output freezes when changing assets with Directory node
Re: Output freezes when changing assets with Directory node
Hi Karol,
nevertheless Ryan's node is broken, changing the binding has no effect in his scene.
Chris' scene is working.
Greets, Stephan
Greets, Stephan
Hi Stephan,
it seems, that Karol is right... if you just bind it correct, everything works as expected. Just havn't noticed, the he bounds the file propertie instead of texture
I have reconect it and it works!
Greetings
Christian
Greetings
Christian
 k, you are right also Chris.
 k, you are right also Chris.Did a mistake in re-binding, the sub-sub-sub-menues in V5 confuses me again and again ...
Greets from Hamburg,
Stephan
mmhhhh....
is it possible that async ist not working if AutoUpdate is enabled?
Greetings
Christian
Greetings
Christian
Will Check
regArts
regArts
