Touch Button Interaction
Re: Touch Button Interaction
Post by chriss0212 » 26 Mar 2013, 08:54
hi kanter
if you take a look in the output properties you will find a TouchPressed bool propertie what you can invert to lock the other button! i have used an event behind the touch because otherwise i get a forbidden loop in the logic!
lockButton.vza
(12.79 KiB) Downloaded 1212 times
Post by chriss0212 » 26 Mar 2013, 10:31
kanter18
Post by kanter18 » 05 Apr 2013, 07:31
I try your idea, and its work !
thank a lot!
kanter18
Post by kanter18 » 05 Apr 2013, 08:42
Ok, it's work, but, in my case, i want to use 6 buttons...
But, Enabled Event Can be used only one time ?
If i press Button One, that Inverse all Enabled in Node Event.
But i can't use It to connect all 6 Invert to Event.
I try to find an idea.
kanter18
Post by kanter18 » 05 Apr 2013, 09:09
I made something with 3 buttons, it's same idea. (posted attachments)
lockButton2.vza
With 3 buttons
(23.5 KiB) Downloaded 1274 times
kanter18
Post by kanter18 » 05 Apr 2013, 09:34
I change my ventuz files. I had 3 Movers.
Thank.
lockButton3.vza
(24.27 KiB) Downloaded 1224 times
