hi kanter
if you take a look in the output properties you will find a TouchPressed bool propertie what you can invert to lock the other button! i have used an event behind the touch because otherwise i get a forbidden loop in the logic!
Touch Button Interaction
Re: Touch Button Interaction
- lockButton.vza
- (12.79 KiB) Downloaded 734 times
I try your idea, and its work !
thank a lot!
thank a lot!
Ok, it's work, but, in my case, i want to use 6 buttons...
But, Enabled Event Can be used only one time ?
If i press Button One, that Inverse all Enabled in Node Event.
But i can't use It to connect all 6 Invert to Event.
I try to find an idea.
I made something with 3 buttons, it's same idea. (posted attachments)
- lockButton2.vza
- With 3 buttons
- (23.5 KiB) Downloaded 723 times
I change my ventuz files. I had 3 Movers.
Thank.
Thank.
- lockButton3.vza
- (24.27 KiB) Downloaded 751 times
