i cant find SD PAL 4:3 or 16:9 Formats in project setting is latest ventuz software release 5.02.2 so
is this normal ?or i miss something?
cant find SD 16:9 Project Format
Re: cant find SD 16:9 Project Format
just use the custom settings
there is almost nobody who needs the settings enymore
greetings
greetings
ahmedahmed1223
but i need this format in project that use camera feed as live feed material projected to 3d shapes.
but the camera didn't cover all the area and it clamp the projection,so how i change camera projection resolution?
ahmed
ahmed
ahmedahmed1223
Will the problem be fixed in the next version of ventuz
Quote..chriss0212 wrote:just use the custom settings
greetings
Custom Settings... there you go
