Anamation Contorl - Pause
Poly Kim
Post by Poly Kim » 02 Jan 2017, 23:10
hi all,
Let me ask one question. Can I pause Ventuz keyframe animation? It would be great if I can have that control.
Poly
lerou
Re: Anamation Contorl - Pause
Post by lerou » 03 Jan 2017, 07:42
you can't pause a state driven animation as it needs to either be in a state or in transition between two states. You can however make it a controlled animation and then take over the progress control. So build your animation and then bind its control to a simple control node. Build some logic to control the progress input. You can even make pausing/unpausing smooth. However the two can't be combined, so you can't set up a state driven animation that reacts to events and then at some point just pause it. It will only work with controlled (and therefore basically stateless) animations.
I've attached such a simple example.
pause_anim.vza
(12.52 KiB) Downloaded 481 times
