How do I map a texture to every character in a Text2D node?
Is there a way to apply a texture to 2D text on a character by character basis? Say for instance I have a simple 100x100 pixel texture that goes from red in the center to blue at the outside. Can I map this texture to each character in a Text2D node? I've already tried modifying the scaling and UV parameters in the 2D mapping, but that only offers a close approximation.
Re: How do I map a texture to every character in a Text2D no
Is this not possible?
Also, can I apply a texture to multiple lines? For example, a texture that fades from white at the top to red at the bottom. If I have multiple lines in a single node, the texture is placed across the ENTIRE block, not each line of text.
