Greetings,
I just downloaded Ventuz PLE and ran the tutorials. On all of them, the Viewport/Background was behind the rest of the content on the scene, so I could not see anything unless I deleted that object. I assume that's not what is mean to happen, so what could be wrong with my setup?
Background hiddes all content
Re: Background hiddes all content
That is obviously not the way it is meant and sounds weird.
What hardware and software setup do you use? Does that behavior appear really in every of the tutorial scenes, if yes can you reproduce the same behavior in a new scene?
Daniel
Daniel
Yes, it happens in all scenes, every single tutorial and scenes created from scratch by me (very basic, still grasping the details).Daniel Willer wrote:That is obviously not the way it is meant and sounds weird.
Daniel
I use windows 7 profesional (32 bits), Dell Optiplex 780 with 4GB RAM. Here you have DxDiag output, in case it's useful for something:
System Information
Time of this report: 3/1/2012, 11:48:43
Machine name: LINTERACTIVA42
Operating System: Windows 7 Professional 32-bit (6.1, Build 7600) (7600.win7_gdr.111025-1503)
Language: Spanish (Regional Setting: Spanish)
System Manufacturer: Dell Inc.
System Model: OptiPlex 780
BIOS: Phoenix ROM BIOS PLUS Version 1.10 A05
Processor: Intel(R) Core(TM)2 Quad CPU Q9400 @ 2.66GHz (4 CPUs), ~2.7GHz
Memory: 4096MB RAM
Available OS Memory: 3548MB RAM
Page File: 2085MB used, 5007MB available
Windows Dir: C:\Windows
DirectX Version: DirectX 11
DX Setup Parameters: Not found
User DPI Setting: Using System DPI
System DPI Setting: 96 DPI (100 percent)
DWM DPI Scaling: Disabled
DxDiag Version: 6.01.7600.16385 32bit Unicode
DxDiag Notes
Display Tab 1: No problems found.
Sound Tab 1: No problems found.
Input Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (retail)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (retail)
DirectMusic: 0/5 (retail)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: Intel(R) Q45/Q43 Express Chipset
Manufacturer: Intel Corporation
Chip type: Intel(R) 4 Series Express Chipset Family
DAC type: Internal
Device Key: Enum\PCI\VEN_8086&DEV_2E12&SUBSYS_04201028&REV_03
Display Memory: 1581 MB
Dedicated Memory: 64 MB
Shared Memory: 1517 MB
Current Mode: 1920 x 1200 (32 bit) (59Hz)
Monitor Name: Monitor PnP genérico
Monitor Model: DELL U2410
Monitor Id: DELF014
Native Mode: 1920 x 1200(p) (59.950Hz)
Output Type: HD15
Driver Name: igdumdx32.dll,igd10umd32.dll
Driver File Version: 8.15.0010.2202 (English)
Driver Version: 8.15.10.2202
DDI Version: 10
Driver Model: WDDM 1.1
Driver Attributes: Final Retail
Driver Date/Size: 8/25/2010 19:28:22, 571904 bytes
WHQL Logo'd: Yes
WHQL Date Stamp:
Device Identifier: {D7B78E66-6D52-11CF-027B-2A24A3C2C535}
Vendor ID: 0x8086
Device ID: 0x2E12
SubSys ID: 0x04201028
Revision ID: 0x0003
Driver Strong Name: oem11.inf:Intel.Mfg:iEGL0:8.15.10.2202:pci\ven_8086&dev_2e12
Rank Of Driver: 00E62001
Video Accel: ModeMPEG2_A ModeMPEG2_C ModeWMV9_B ModeWMV9_C ModeVC1_B ModeVC1_C
Deinterlace Caps: {BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(YV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(NV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(NV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(IMC1,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC1,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC1,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(IMC2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(IMC3,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC3,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC3,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(IMC4,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC4,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC4,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
D3D9 Overlay: Supported
DXVA-HD: Supported
DDraw Status: Enabled
D3D Status: Enabled
AGP Status: Enabled
Sound Devices
Description: Altavoces (SoundMAX Integrated Digital High Definition Audio)
Default Sound Playback: Yes
Default Voice Playback: Yes
Hardware ID: HDAUDIO\FUNC_01&VEN_11D4&DEV_194A&SUBSYS_10280420&REV_1004
Manufacturer ID: 1
Product ID: 100
Type: WDM
Driver Name: ADIHdAud.sys
Driver Version: 6.10.0001.7260 (English)
WHQL Logo'd: Yes
Date and Size: 6/23/2009 00:02:30, 381440 bytes
Other Files:
Driver Provider: AnalogDevices
HW Accel Level: Basic
Cap Flags: 0xF1F
Min/Max Sample Rate: 100, 200000
Static/Strm HW Mix Bufs: 1, 0
Static/Strm HW 3D Bufs: 0, 0
HW Memory: 0
Voice Management: No
EAX(tm) 2.0 Listen/Src: No, No
I3DL2(tm) Listen/Src: No, No
Sensaura(tm) ZoomFX(tm): No
Sound Capture Devices
Description: Micrófono (SoundMAX Integrated Digital High Definition Audio)
Default Sound Capture: Yes
Default Voice Capture: Yes
Cap Flags: 0x1
Format Flags: 0xFFFFF
Description: Entrada trasera (SoundMAX Integrated Digital High Definition Audio)
Default Sound Capture: No
Default Voice Capture: No
Cap Flags: 0x1
DirectInput Devices
Device Name: Mouse
Attached: 1
Controller ID: n/a
Vendor/Product ID: n/a
FF Driver: n/a
Device Name: Teclado
Attached: 1
Controller ID: n/a
FF Driver: n/a
Poll w/ Interrupt: No
USB Devices
+ Concentrador raíz USB
| Vendor/Product ID: 0x8086, 0x3A65
| Matching Device ID: usb\root_hub
| Service: usbhub
| Driver: usbhub.sys, 3/29/2011 04:07:26, 258560 bytes
| Driver: usbd.sys, 3/29/2011 04:06:34, 5888 bytes
Gameport Devices
PS/2 Devices
+ Dispositivo de teclado HID
| Vendor/Product ID: 0x413C, 0x2106
| Matching Device ID: hid_device_system_keyboard
| Service: kbdhid
| Driver: kbdhid.sys, 7/14/2009 00:45:09, 28160 bytes
| Driver: kbdclass.sys, 7/14/2009 02:20:36, 42576 bytes
+ Controlador de teclado de Terminal Server
| Matching Device ID: root\rdp_kbd
| Upper Filters: kbdclass
| Service: TermDD
| Driver: i8042prt.sys, 7/14/2009 00:11:24, 80896 bytes
+ Mouse compatible con HID
| Vendor/Product ID: 0x046D, 0xC05A
| Matching Device ID: hid_device_system_mouse
| Service: mouhid
| Driver: mouhid.sys, 7/14/2009 00:45:08, 26112 bytes
| Driver: mouclass.sys, 7/14/2009 02:20:44, 41552 bytes
+ Controlador de mouse de Terminal Server
| Matching Device ID: root\rdp_mou
| Upper Filters: mouclass
| Service: TermDD
| Driver: termdd.sys, 7/14/2009 02:19:10, 51776 bytes
| Driver: sermouse.sys, 7/14/2009 00:45:08, 19968 bytes
Disk & DVD/CD-ROM Drives
Drive: C:
Free Space: 23.3 GB
Total Space: 121.7 GB
File System: NTFS
Model: WDC WD2500AAJS-75M0A0
Drive: E:
Free Space: 13.1 GB
Total Space: 30.8 GB
File System: NTFS
Drive: F:
Free Space: 5.6 GB
Total Space: 5.6 GB
File System: FAT32
Drive: D:
Model: TSSTcorp DVD+-RW TS-H653G
Driver: c:\windows\system32\drivers\cdrom.sys, 6.01.7600.16385 (Spanish), 7/14/2009 00:11:26, 108544 bytes
System Devices
Name: Controladora de host universal USB de la familia Intel(R) ICH10 - 3A69
Device ID: PCI\VEN_8086&DEV_3A69&SUBSYS_04201028&REV_02\3&172E68DD&0&D2
Driver: C:\Windows\system32\drivers\usbuhci.sys, 6.01.7600.20934 (English), 3/29/2011 04:06:37, 24064 bytes
Driver: C:\Windows\system32\drivers\usbport.sys, 6.01.7600.20934 (Spanish), 3/29/2011 04:06:47, 284160 bytes
Driver: C:\Windows\system32\drivers\usbhub.sys, 6.01.7600.20934 (Spanish), 3/29/2011 04:07:26, 258560 bytes
Name: Intel(R) Q45/Q43 Express Chipset
Device ID: PCI\VEN_8086&DEV_2E13&SUBSYS_04201028&REV_03\3&172E68DD&0&11
Driver: n/a
Name: Controladora de host universal USB de la familia Intel(R) ICH10 - 3A68
Device ID: PCI\VEN_8086&DEV_3A68&SUBSYS_04201028&REV_02\3&172E68DD&0&D1
Device ID: PCI\VEN_8086&DEV_2E12&SUBSYS_04201028&REV_03\3&172E68DD&0&10
Driver: C:\Windows\system32\DRIVERS\igdkmd32.sys, 8.15.0010.2202 (English), 8/25/2010 19:31:30, 9024512 bytes
Driver: C:\Windows\system32\igdumd32.dll, 8.15.0010.2202 (English), 8/25/2010 19:31:30, 4967424 bytes
Driver: C:\Windows\system32\igkrng500.bin, 7/28/2010 20:01:10, 982240 bytes
Driver: C:\Windows\system32\igcompkrng500.bin, 7/28/2010 20:01:14, 439308 bytes
Driver: C:\Windows\system32\igfcg500m.bin, 7/28/2010 20:01:12, 92356 bytes
Driver: C:\Windows\system32\iglhxs32.vp, 8/25/2010 19:58:00, 51432 bytes
Driver: C:\Windows\system32\iglhxo32.vp, 1/26/2010 02:43:18, 60015 bytes
Driver: C:\Windows\system32\iglhxc32.vp, 1/26/2010 02:43:18, 60226 bytes
Driver: C:\Windows\system32\iglhxg32.vp, 1/26/2010 02:43:20, 60254 bytes
Driver: C:\Windows\system32\iglhxa32.vp, 1/26/2010 02:43:18, 1090 bytes
Driver: C:\Windows\system32\iglhxa32.cpa, 1/26/2010 02:43:18, 1921265 bytes
Driver: C:\Windows\system32\iglhcp32.dll, 1/26/2010 02:43:18, 143360 bytes
Driver: C:\Windows\system32\iglhsip32.dll, 1/26/2010 02:43:18, 208896 bytes
Driver: C:\Windows\system32\hccutils.dll, 8.15.0010.2202 (English), 8/25/2010 18:59:16, 94720 bytes
Driver: C:\Windows\system32\igfxsrvc.dll, 8.15.0010.2202 (English), 8/25/2010 18:59:42, 57344 bytes
Driver: C:\Windows\system32\igfxsrvc.exe, 8.15.0010.2202 (English), 8/25/2010 19:45:42, 266776 bytes
Driver: C:\Windows\system32\igfxpph.dll, 8.15.0010.2202 (English), 8/25/2010 19:00:00, 194560 bytes
Driver: C:\Windows\system32\igfxcpl.cpl, 8.15.0010.2202 (English), 8/25/2010 18:59:58, 115200 bytes
Driver: C:\Windows\system32\igfxdev.dll, 8.15.0010.2202 (English), 8/25/2010 18:59:06, 228864 bytes
Driver: C:\Windows\system32\igfxdo.dll, 8.15.0010.2202 (English), 8/25/2010 18:59:24, 130048 bytes
Driver: C:\Windows\system32\igfxtray.exe, 8.15.0010.2202 (English), 8/25/2010 19:45:44, 136216 bytes
Driver: C:\Windows\system32\hkcmd.exe, 8.15.0010.2202 (English), 8/25/2010 19:45:36, 171032 bytes
Driver: C:\Windows\system32\igfxress.dll, 8.15.0010.2202 (English), 8/25/2010 18:59:06, 828928 bytes
Driver: C:\Windows\system32\igfxpers.exe, 8.15.0010.2202 (English), 8/25/2010 19:45:40, 170520 bytes
Driver: C:\Windows\system32\igfxTMM.dll, 8.15.0010.2202 (English), 8/25/2010 18:59:58, 261632 bytes
Driver: C:\Windows\system32\TVWSetup.exe, 1.00.0001.0000 (English), 8/25/2010 19:46:02, 8198680 bytes
Driver: C:\Windows\system32\gfxSrvc.dll, 8.15.0010.2202 (Spanish), 8/25/2010 18:59:10, 120320 bytes
Driver: C:\Windows\system32\GfxUI.exe, 8.15.0010.2202 (Spanish), 8/25/2010 19:45:32, 3156504 bytes
Driver: C:\Windows\system32\GfxUI.exe.config, 1/26/2010 02:49:50, 151 bytes
Driver: C:\Windows\system32\IGFXDEVLib.dll, 1.00.0000.0000 (Invariant Language), 8/25/2010 18:59:08, 4096 bytes
Driver: C:\Windows\system32\igfxext.exe, 8.15.0010.2202 (English), 8/25/2010 19:45:38, 179224 bytes
Driver: C:\Windows\system32\igfxexps.dll, 8.15.0010.2202 (English), 8/25/2010 19:00:00, 23552 bytes
Driver: C:\Windows\system32\igfxrara.lrc, 8.15.0010.2202 (English), 8/25/2010 19:02:26, 84480 bytes
Driver: C:\Windows\system32\igfxrchs.lrc, 8.15.0010.2202 (English), 8/25/2010 19:02:26, 81920 bytes
Driver: C:\Windows\system32\igfxrcht.lrc, 8.15.0010.2202 (English), 8/25/2010 19:02:26, 81920 bytes
Driver: C:\Windows\system32\igfxrdan.lrc, 8.15.0010.2202 (English), 8/25/2010 19:02:26, 84992 bytes
Driver: C:\Windows\system32\igfxrdeu.lrc, 8.15.0010.2202 (English), 8/25/2010 19:02:28, 86016 bytes
Driver: C:\Windows\system32\igfxrenu.lrc, 8.15.0010.2202 (English), 8/25/2010 18:59:06, 85504 bytes
Driver: C:\Windows\system32\igfxresn.lrc, 8.15.0010.2202 (English), 8/25/2010 19:02:34, 86528 bytes
Driver: C:\Windows\system32\igfxrfin.lrc, 8.15.0010.2202 (English), 8/25/2010 19:02:28, 85504 bytes
Driver: C:\Windows\system32\igfxrfra.lrc, 8.15.0010.2202 (English), 8/25/2010 19:02:28, 86528 bytes
Driver: C:\Windows\system32\igfxrheb.lrc, 8.15.0010.2202 (English), 8/25/2010 19:02:30, 84480 bytes
Driver: C:\Windows\system32\igfxrita.lrc, 8.15.0010.2202 (English), 8/25/2010 19:02:30, 86016 bytes
Driver: C:\Windows\system32\igfxrjpn.lrc, 8.15.0010.2202 (English), 8/25/2010 19:02:30, 82944 bytes
Driver: C:\Windows\system32\igfxrkor.lrc, 8.15.0010.2202 (English), 8/25/2010 19:02:30, 82944 bytes
Driver: C:\Windows\system32\igfxrnld.lrc, 8.15.0010.2202 (English), 8/25/2010 19:02:28, 86016 bytes
Driver: C:\Windows\system32\igfxrnor.lrc, 8.15.0010.2202 (English), 8/25/2010 19:02:32, 85504 bytes
Driver: C:\Windows\system32\igfxrplk.lrc, 8.15.0010.2202 (English), 8/25/2010 19:02:32, 86016 bytes
Driver: C:\Windows\system32\igfxrptb.lrc, 8.15.0010.2202 (English), 8/25/2010 19:02:32, 85504 bytes
Driver: C:\Windows\system32\igfxrptg.lrc, 8.15.0010.2202 (English), 8/25/2010 19:02:32, 86016 bytes
Driver: C:\Windows\system32\igfxrrus.lrc, 8.15.0010.2202 (English), 8/25/2010 19:02:32, 86016 bytes
Driver: C:\Windows\system32\igfxrsky.lrc, 8.15.0010.2202 (English), 8/25/2010 19:02:36, 86016 bytes
Driver: C:\Windows\system32\igfxrslv.lrc, 8.15.0010.2202 (English), 8/25/2010 19:02:36, 85504 bytes
Driver: C:\Windows\system32\igfxrsve.lrc, 8.15.0010.2202 (English), 8/25/2010 19:02:34, 85504 bytes
Driver: C:\Windows\system32\igfxrtha.lrc, 8.15.0010.2202 (English), 8/25/2010 19:02:34, 84992 bytes
Driver: C:\Windows\system32\igfxrcsy.lrc, 8.15.0010.2202 (English), 8/25/2010 19:02:26, 85504 bytes
Driver: C:\Windows\system32\igfxrell.lrc, 8.15.0010.2202 (English), 8/25/2010 19:02:28, 86528 bytes
Driver: C:\Windows\system32\igfxrhun.lrc, 8.15.0010.2202 (English), 8/25/2010 19:02:30, 85504 bytes
Driver: C:\Windows\system32\igfxrtrk.lrc, 8.15.0010.2202 (English), 8/25/2010 19:02:34, 85504 bytes
Driver: C:\Windows\system32\Gfxres.ar-SA.resources, 7/28/2010 19:24:54, 139830 bytes
Driver: C:\Windows\system32\Gfxres.cs-CZ.resources, 7/28/2010 19:24:56, 118684 bytes
Driver: C:\Windows\system32\Gfxres.da-DK.resources, 7/28/2010 19:24:56, 114179 bytes
Driver: C:\Windows\system32\Gfxres.de-DE.resources, 7/28/2010 19:24:58, 122638 bytes
Driver: C:\Windows\system32\Gfxres.el-GR.resources, 7/28/2010 19:25:00, 178288 bytes
Driver: C:\Windows\system32\Gfxres.es-ES.resources, 7/28/2010 19:25:00, 122858 bytes
Driver: C:\Windows\system32\Gfxres.en-US.resources, 7/28/2010 19:24:40, 110156 bytes
Driver: C:\Windows\system32\Gfxres.fi-FI.resources, 7/28/2010 19:25:02, 118631 bytes
Driver: C:\Windows\system32\Gfxres.fr-FR.resources, 7/28/2010 19:25:02, 120695 bytes
Driver: C:\Windows\system32\Gfxres.he-IL.resources, 7/28/2010 19:25:04, 133680 bytes
Driver: C:\Windows\system32\Gfxres.hu-HU.resources, 7/28/2010 19:25:04, 119533 bytes
Driver: C:\Windows\system32\Gfxres.it-IT.resources, 7/28/2010 19:25:06, 125477 bytes
Driver: C:\Windows\system32\Gfxres.ja-JP.resources, 7/28/2010 19:25:08, 136327 bytes
Driver: C:\Windows\system32\Gfxres.ko-KR.resources, 7/28/2010 19:25:08, 123164 bytes
Driver: C:\Windows\system32\Gfxres.nb-NO.resources, 7/28/2010 19:25:10, 114779 bytes
Driver: C:\Windows\system32\Gfxres.nl-NL.resources, 7/28/2010 19:25:10, 119513 bytes
Driver: C:\Windows\system32\Gfxres.pl-PL.resources, 7/28/2010 19:25:12, 118317 bytes
Driver: C:\Windows\system32\Gfxres.pt-BR.resources, 7/28/2010 19:25:12, 120287 bytes
Driver: C:\Windows\system32\Gfxres.pt-PT.resources, 7/28/2010 19:25:14, 118997 bytes
Driver: C:\Windows\system32\Gfxres.ru-RU.resources, 7/28/2010 19:25:16, 165251 bytes
Driver: C:\Windows\system32\Gfxres.sk-SK.resources, 7/28/2010 19:25:16, 117984 bytes
Driver: C:\Windows\system32\Gfxres.sl-SI.resources, 7/28/2010 19:25:18, 114308 bytes
Driver: C:\Windows\system32\Gfxres.sv-SE.resources, 7/28/2010 19:25:18, 119286 bytes
Driver: C:\Windows\system32\Gfxres.th-TH.resources, 7/28/2010 19:25:20, 189408 bytes
Driver: C:\Windows\system32\Gfxres.tr-TR.resources, 7/28/2010 19:25:22, 121121 bytes
Driver: C:\Windows\system32\Gfxres.zh-CN.resources, 7/28/2010 19:25:22, 102843 bytes
Driver: C:\Windows\system32\Gfxres.zh-TW.resources, 7/28/2010 19:25:24, 103997 bytes
Driver: C:\Windows\system32\ig4icd32.dll, 8.15.0010.2202 (English), 8/25/2010 19:09:34, 11040256 bytes
Driver: C:\Windows\system32\igd10umd32.dll, 8.15.0010.2202 (English), 8/25/2010 19:23:14, 4411904 bytes
Driver: C:\Windows\system32\d3dx10_40.dll, 9.24.0950.2656 (English), 1/26/2010 02:43:20, 452440 bytes
Driver: C:\Windows\system32\igdumdx32.dll, 8.15.0010.2202 (English), 8/25/2010 19:28:22, 571904 bytes
Driver: C:\Windows\system32\igfxCoIn_v2202.dll, 1.02.0030.0000 (English), 8/25/2010 19:39:46, 81920 bytes
Name: Controladora de host universal USB de la familia Intel(R) ICH10 - 3A67
Device ID: PCI\VEN_8086&DEV_3A67&SUBSYS_04201028&REV_02\3&172E68DD&0&D0
Name: Puerto raíz PCI Express del chipset Intel(R) 4 Series - 2E11
Device ID: PCI\VEN_8086&DEV_2E11&SUBSYS_04201028&REV_03\3&172E68DD&0&08
Driver: C:\Windows\system32\DRIVERS\pci.sys, 6.01.7600.16385 (Spanish), 7/14/2009 02:20:45, 153680 bytes
Name: Puerto raíz PCI Express 2 de la familia Intel(R) ICH10 - 3A72
Device ID: PCI\VEN_8086&DEV_3A72&SUBSYS_04201028&REV_02\3&172E68DD&0&E1
Name: Controladora de host universal USB de la familia Intel(R) ICH10 - 3A66
Device ID: PCI\VEN_8086&DEV_3A66&SUBSYS_04201028&REV_02\3&172E68DD&0&EA
Name: Controladora de procesador del chipset Intel(R) 4 Series a E/S - 2E10
Device ID: PCI\VEN_8086&DEV_2E10&SUBSYS_04201028&REV_03\3&172E68DD&0&00
Driver: n/a
Name: Puerto raíz PCI Express 1 de la familia Intel(R) ICH10 - 3A70
Device ID: PCI\VEN_8086&DEV_3A70&SUBSYS_04201028&REV_02\3&172E68DD&0&E0
Name: Controladora de host universal USB de la familia Intel(R) ICH10 - 3A65
Device ID: PCI\VEN_8086&DEV_3A65&SUBSYS_04201028&REV_02\3&172E68DD&0&E9
Name: Intel(R) ICH8R/ICH9R/ICH10R/DO/5 Series/3400 Series SATA RAID Controller
Device ID: PCI\VEN_8086&DEV_2822&SUBSYS_04201028&REV_02\3&172E68DD&0&FA
Driver: C:\Windows\system32\DRIVERS\iaStor.sys, 9.06.0000.1014 (English), 3/4/2010 04:33:26, 435736 bytes
Name: Controladora de High Definition Audio
Device ID: PCI\VEN_8086&DEV_3A6E&SUBSYS_04201028&REV_02\3&172E68DD&0&D8
Driver: C:\Windows\system32\DRIVERS\hdaudbus.sys, 6.01.7600.16385 (Spanish), 7/14/2009 00:50:56, 108544 bytes
Name: Controladora de host universal USB de la familia Intel(R) ICH10 - 3A64
Device ID: PCI\VEN_8086&DEV_3A64&SUBSYS_04201028&REV_02\3&172E68DD&0&E8
Name: Puente PCI Intel(R) 82801 - 244E
Device ID: PCI\VEN_8086&DEV_244E&SUBSYS_04201028&REV_A2\3&172E68DD&0&F0
Name: Controladora de host mejorado USB de la familia Intel(R) ICH10 - 3A6C
Device ID: PCI\VEN_8086&DEV_3A6C&SUBSYS_04201028&REV_02\3&172E68DD&0&D7
Driver: C:\Windows\system32\drivers\usbehci.sys, 6.01.7600.20934 (English), 3/29/2011 04:06:43, 43008 bytes
Name: Controladora de SMBus de la familia Intel(R) ICH10 - 3A60
Device ID: PCI\VEN_8086&DEV_3A60&SUBSYS_04201028&REV_02\3&172E68DD&0&FB
Driver: n/a
Name: Intel(R) 82567LM-3 Gigabit Network Connection
Device ID: PCI\VEN_8086&DEV_10DE&SUBSYS_02761028&REV_02\3&172E68DD&0&C8
Driver: C:\Windows\system32\DRIVERS\e1k6232.sys, 11.06.0092.0000 (Spanish), 4/6/2010 09:36:20, 224424 bytes
Driver: C:\Windows\system32\e1k6232.din, 10/9/2009 20:43:54, 3138 bytes
Driver: C:\Windows\system32\NicCo36.dll, 2.01.0002.0000 (English), 5/26/2009 19:05:46, 28792 bytes
Driver: C:\Windows\system32\NicInstK.dll, 9.10.0041.0000 (English), 4/14/2010 09:47:46, 74944 bytes
Driver: C:\Windows\system32\e1kmsg.dll, 10.00.0059.0000 (English), 4/2/2010 09:56:24, 68264 bytes
Name: Controladora de host mejorado USB de la familia Intel(R) ICH10 - 3A6A
Device ID: PCI\VEN_8086&DEV_3A6A&SUBSYS_04201028&REV_02\3&172E68DD&0&EF
Name: Controladora de interfaz LPC Intel(R) ICH10DO - 3A14
Device ID: PCI\VEN_8086&DEV_3A14&SUBSYS_04201028&REV_02\3&172E68DD&0&F8
Driver: C:\Windows\system32\DRIVERS\msisadrv.sys, 6.01.7600.16385 (English), 7/14/2009 02:20:43, 13888 bytes
DirectShow Filters
DirectShow Filters:
WMAudio Decoder DMO,0x00800800,1,1,WMADMOD.DLL,6.01.7600.16385
WMAPro over S/PDIF DMO,0x00600800,1,1,WMADMOD.DLL,6.01.7600.16385
WMSpeech Decoder DMO,0x00600800,1,1,WMSPDMOD.DLL,6.01.7600.16385
MP3 Decoder DMO,0x00600800,1,1,mp3dmod.dll,6.01.7600.16385
Mpeg4s Decoder DMO,0x00800001,1,1,mp4sdecd.dll,6.01.7600.16385
WMV Screen decoder DMO,0x00600800,1,1,wmvsdecd.dll,6.01.7600.16385
WMVideo Decoder DMO,0x00800001,1,1,wmvdecod.dll,6.01.7600.16597
Mpeg43 Decoder DMO,0x00800001,1,1,mp43decd.dll,6.01.7600.16385
Mpeg4 Decoder DMO,0x00800001,1,1,mpg4decd.dll,6.01.7600.16385
CyberLink AudioCD Filter,0x00600000,0,1,CLAudioCD.ax,5.00.0000.4417
CyberLink Audio Spectrum Analyzer,0x00200000,1,1,CLAudSpa.ax,1.00.0000.0924
DV Muxer,0x00400000,0,0,qdv.dll,6.06.7600.16385
CyberLink Audio Wizard,0x00600010,1,1,CLAudWizard.ax,1.00.0000.3616
Color Space Converter,0x00400001,1,1,quartz.dll,6.06.7600.16905
WM ASF Reader,0x00400000,0,0,qasf.dll,12.00.7600.16385
Screen Capture filter,0x00200000,0,1,wmpsrcwp.dll,12.00.7600.16385
AVI Splitter,0x00600000,1,1,quartz.dll,6.06.7600.16905
VGA 16 Color Ditherer,0x00400000,1,1,quartz.dll,6.06.7600.16905
SBE2MediaTypeProfile,0x00200000,0,0,sbe.dll,6.06.7600.16724
Microsoft DTV-DVD Video Decoder,0x005fffff,2,4,msmpeg2vdec.dll,6.01.7140.0000
CyberLink DVD Navigator,0x00200000,0,3,CLNavX.ax,8.00.0000.2808
AC3 Parser Filter,0x00600000,1,1,mpg2splt.ax,6.06.7600.16724
StreamBufferSink,0x00200000,0,0,sbe.dll,6.06.7600.16724
Microsoft TV Captions Decoder,0x00200001,1,0,MSTVCapn.dll,6.01.7600.16907
MJPEG Decompressor,0x00600000,1,1,quartz.dll,6.06.7600.16905
CBVA DMO wrapper filter,0x00200000,1,1,cbva.dll,6.01.7600.16385
MPEG-I Stream Splitter,0x00600000,1,2,quartz.dll,6.06.7600.16905
SAMI (CC) Parser,0x00400000,1,1,quartz.dll,6.06.7600.16905
VBI Codec,0x00600000,1,4,VBICodec.ax,6.06.7600.16385
MPEG-2 Splitter,0x005fffff,1,0,mpg2splt.ax,6.06.7600.16724
Closed Captions Analysis Filter,0x00200000,2,5,cca.dll,6.06.7600.16385
SBE2FileScan,0x00200000,0,0,sbe.dll,6.06.7600.16724
Microsoft MPEG-2 Video Encoder,0x00200000,1,1,msmpeg2enc.dll,6.01.7600.16385
CyberLink Demultiplexer,0x00200000,1,0,cldemuxer.ax,1.00.0000.4528
Internal Script Command Renderer,0x00800001,1,0,quartz.dll,6.06.7600.16905
MPEG Audio Decoder,0x03680001,1,1,quartz.dll,6.06.7600.16905
DV Splitter,0x00600000,1,2,qdv.dll,6.06.7600.16385
Video Mixing Renderer 9,0x00200000,1,0,quartz.dll,6.06.7600.16905
Microsoft MPEG-2 Encoder,0x00200000,2,1,msmpeg2enc.dll,6.01.7600.16385
ACM Wrapper,0x00600000,1,1,quartz.dll,6.06.7600.16905
Video Renderer,0x00800001,1,0,quartz.dll,6.06.7600.16905
MPEG-2 Video Stream Analyzer,0x00200000,0,0,sbe.dll,6.06.7600.16724
Line 21 Decoder,0x00600000,1,1,qdvd.dll,6.06.7600.21077
Video Port Manager,0x00600000,2,1,quartz.dll,6.06.7600.16905
Video Renderer,0x00400000,1,0,quartz.dll,6.06.7600.16905
VPS Decoder,0x00200000,0,0,WSTPager.ax,6.06.7600.16385
WM ASF Writer,0x00400000,0,0,qasf.dll,12.00.7600.16385
VBI Surface Allocator,0x00600000,1,1,vbisurf.ax,6.01.7600.16385
CyberLink Audio Decoder,0x00600000,1,1,Claud.ax,6.03.0000.1322
File writer,0x00200000,1,0,qcap.dll,6.06.7600.16385
iTV Data Sink,0x00600000,1,0,itvdata.dll,6.06.7600.16385
iTV Data Capture filter,0x00600000,1,1,itvdata.dll,6.06.7600.16385
WAV Dest,0x00000000,0,0,,
DVD Navigator,0x00200000,0,3,qdvd.dll,6.06.7600.21077
Microsoft TV Subtitles Decoder,0x00200001,1,0,MSTVCapn.dll,6.01.7600.16907
Overlay Mixer2,0x00200000,1,1,qdvd.dll,6.06.7600.21077
CyberLink TimeStretch Filter,0x00200000,1,1,clauts.ax,1.00.0000.5423
AVI Draw,0x00600064,9,1,quartz.dll,6.06.7600.16905
RDP DShow Redirection Filter,0xffffffff,1,0,DShowRdpFilter.dll,
CyberLink Audio Effect,0x00200000,1,1,CLAudFx.ax,6.00.0000.5723
Microsoft MPEG-2 Audio Encoder,0x00200000,1,1,msmpeg2enc.dll,6.01.7600.16385
WST Pager,0x00200000,1,1,WSTPager.ax,6.06.7600.16385
MPEG-2 Demultiplexer,0x00600000,1,1,mpg2splt.ax,6.06.7600.16724
DV Video Decoder,0x00800000,1,1,qdv.dll,6.06.7600.16385
CyberLink Tzan Filter,0x00200000,1,1,CLTzan.ax,3.00.0001.2905
Cyberlink SubTitle Importor,0x00200000,1,1,CLSubTitle.ax,1.00.0000.6016
SampleGrabber,0x00200000,1,1,qedit.dll,6.06.7600.16385
Null Renderer,0x00200000,1,0,qedit.dll,6.06.7600.16385
MPEG-2 Sections and Tables,0x005fffff,1,0,Mpeg2Data.ax,6.06.7600.16867
Microsoft AC3 Encoder,0x00200000,1,1,msac3enc.dll,6.01.7600.16385
StreamBufferSource,0x00200000,0,0,sbe.dll,6.06.7600.16724
Smart Tee,0x00200000,1,2,qcap.dll,6.06.7600.16385
Overlay Mixer,0x00200000,0,0,qdvd.dll,6.06.7600.21077
CyberLink Video Effect,0x00200000,1,1,CLVidFx.ax,1.00.0000.1523
CyberLink Video/SP Decoder,0x00600000,2,3,CLVSD.ax,8.04.0000.0205
AVI Decompressor,0x00600000,1,1,quartz.dll,6.06.7600.16905
NetBridge,0x00200000,2,0,netbridge.dll,6.01.7600.16385
AVI/WAV File Source,0x00400000,0,2,quartz.dll,6.06.7600.16905
Wave Parser,0x00400000,1,1,quartz.dll,6.06.7600.16905
MIDI Parser,0x00400000,1,1,quartz.dll,6.06.7600.16905
Multi-file Parser,0x00400000,1,1,quartz.dll,6.06.7600.16905
File stream renderer,0x00400000,1,1,quartz.dll,6.06.7600.16905
CyberLink Line21 Decoder Filter,0x00200000,0,2,CLLine21.ax,4.00.0000.9625
Microsoft DTV-DVD Audio Decoder,0x005fffff,1,1,msmpeg2adec.dll,6.01.7140.0000
StreamBufferSink2,0x00200000,0,0,sbe.dll,6.06.7600.16724
AVI Mux,0x00200000,1,0,qcap.dll,6.06.7600.16385
Line 21 Decoder 2,0x00600002,1,1,quartz.dll,6.06.7600.16905
File Source (Async.),0x00400000,0,1,quartz.dll,6.06.7600.16905
File Source (URL),0x00400000,0,1,quartz.dll,6.06.7600.16905
Media Center Extender Encryption Filter,0x00200000,2,2,Mcx2Filter.dll,6.01.7600.16385
AudioRecorder WAV Dest,0x00200000,0,0,WavDest.dll,
AudioRecorder Wave Form,0x00200000,0,0,WavDest.dll,
SoundRecorder Null Renderer,0x00200000,0,0,WavDest.dll,
Infinite Pin Tee Filter,0x00200000,1,1,qcap.dll,6.06.7600.16385
Enhanced Video Renderer,0x00200000,1,0,evr.dll,6.01.7600.20574
BDA MPEG2 Transport Information Filter,0x00200000,2,0,psisrndr.ax,6.06.7600.16867
MPEG Video Decoder,0x40000001,1,1,quartz.dll,6.06.7600.16905
WDM Streaming Tee/Splitter Devices:
Convertidor de derivador/consumidor a consumidor,0x00200000,1,1,ksproxy.ax,6.01.7600.16385
Video Compressors:
WMVideo8 Encoder DMO,0x00600800,1,1,wmvxencd.dll,6.01.7600.16385
WMVideo9 Encoder DMO,0x00600800,1,1,wmvencod.dll,6.01.7600.16385
MSScreen 9 encoder DMO,0x00600800,1,1,wmvsencd.dll,6.01.7600.16385
DV Video Encoder,0x00200000,0,0,qdv.dll,6.06.7600.16385
MJPEG Compressor,0x00200000,0,0,quartz.dll,6.06.7600.16905
Códec Cinepak por Radius,0x00200000,1,1,qcap.dll,6.06.7600.16385
Logitech Video (I420),0x00200000,1,1,qcap.dll,6.06.7600.16385
Códec Intel IYUV,0x00200000,1,1,qcap.dll,6.06.7600.16385
Microsoft RLE,0x00200000,1,1,qcap.dll,6.06.7600.16385
Microsoft Video 1,0x00200000,1,1,qcap.dll,6.06.7600.16385
Audio Compressors:
WM Speech Encoder DMO,0x00600800,1,1,WMSPDMOE.DLL,6.01.7600.16385
WMAudio Encoder DMO,0x00600800,1,1,WMADMOE.DLL,6.01.7600.16385
IMA ADPCM,0x00200000,1,1,quartz.dll,6.06.7600.16905
Microsoft ADPCM,0x00200000,1,1,quartz.dll,6.06.7600.16905
GSM 6.10,0x00200000,1,1,quartz.dll,6.06.7600.16905
Ley A CCITT,0x00200000,1,1,quartz.dll,6.06.7600.16905
Ley u de CCITT,0x00200000,1,1,quartz.dll,6.06.7600.16905
MPEG Layer-3,0x00200000,1,1,quartz.dll,6.06.7600.16905
Audio Capture Sources:
Micrófono (SoundMAX Integrated ,0x00200000,0,0,qcap.dll,6.06.7600.16385
Entrada trasera (SoundMAX Integ,0x00200000,0,0,qcap.dll,6.06.7600.16385
PBDA CP Filters:
PBDA DTFilter,0x00600000,1,1,CPFilters.dll,6.06.7600.16724
PBDA ETFilter,0x00200000,0,0,CPFilters.dll,6.06.7600.16724
PBDA PTFilter,0x00200000,0,0,CPFilters.dll,6.06.7600.16724
Midi Renderers:
Default MidiOut Device,0x00800000,1,0,quartz.dll,6.06.7600.16905
Microsoft GS Wavetable Synth,0x00200000,1,0,quartz.dll,6.06.7600.16905
WDM Streaming Capture Devices:
SoundMAX HD Audio I,0x00200000,1,1,ksproxy.ax,6.01.7600.16385
WDM Streaming Rendering Devices:
SoundMAX HD Audio O,0x00200000,1,1,ksproxy.ax,6.01.7600.16385
BDA Network Providers:
Microsoft ATSC Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7600.16867
Microsoft DVBC Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7600.16867
Microsoft DVBS Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7600.16867
Microsoft DVBT Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7600.16867
Microsoft Network Provider,0x00200000,0,1,MSNP.ax,6.06.7600.16867
Video Capture Sources:
Virtual Cam,0x00200000,0,1,VCamFilters.ax,
Multi-Instance Capable VBI Codecs:
BDA Transport Information Renderers:
BDA MPEG2 Transport Information Filter,0x00600000,2,0,psisrndr.ax,6.06.7600.16867
MPEG-2 Sections and Tables,0x00600000,1,0,Mpeg2Data.ax,6.06.7600.16867
BDA CP/CA Filters:
Decrypt/Tag,0x00600000,1,1,EncDec.dll,6.06.7600.16899
Encrypt/Tag,0x00200000,0,0,EncDec.dll,6.06.7600.16899
PTFilter,0x00200000,0,0,EncDec.dll,6.06.7600.16899
XDS Codec,0x00200000,0,0,EncDec.dll,6.06.7600.16899
WDM Streaming Communication Transforms:
Audio Renderers:
Altavoces (SoundMAX Integrated ,0x00200000,1,0,quartz.dll,6.06.7600.16905
CyberLink Audio Renderer,0x00200000,1,0,cladr.ax,6.00.0000.5222
Default DirectSound Device,0x00800000,1,0,quartz.dll,6.06.7600.16905
Default WaveOut Device,0x00200000,1,0,quartz.dll,6.06.7600.16905
DirectSound: Altavoces (SoundMAX Integrated Digital High Definition Audio),0x00200000,1,0,quartz.dll,6.06.7600.16905
EVR Power Information
Current Setting: {5C67A112-A4C9-483F-B4A7-1D473BECAFDC} (Quality)
Quality Flags: 2576
Enabled:
Force throttling
Allow half deinterlace
Allow scaling
Decode Power Usage: 100
Balanced Flags: 1424
Enabled:
Force throttling
Allow batching
Force half deinterlace
Force scaling
Decode Power Usage: 50
PowerFlags: 1424
Enabled:
Force throttling
Allow batching
Force scaling
Decode Power Usage: 0
The problem is caused by your Intel Graphics solution. We do not support those intel graphic chips because it's a gamble if they do things the right way.
Use a machine with a standard ATI or Nvidia graphic board and it will work like charm.
Sorry for that.
Daniel
Sorry for that.
Daniel
Ok thanks. I'm just using a standard workstation right now, to learn and evaluate how fast we can do things. We well of course use "real" computers when showtime aproachesDaniel Willer wrote:The problem is caused by your Intel Graphics solution. We do not support those intel graphic chips because it's a gamble if they do things the right way.
Sorry for that.
Daniel
My advice is: by all means try to work/develop on the final hardware as soon as possible (especially the graphics adapter, if you're planning to use "consumer grade" products).I'm just using a standard workstation right now, to learn and evaluate how fast we can do things. We well of course use "real" computers when showtime aproaches
We've been bitten before by really nasty bugs that only became apparent when we deployed the Ventuz-presentations on the final machines. At one time we had to rip out 10 ATI-cards the night before rollout due to a ATI driver bug (see http://forum-archive.ventuz.com/forums/ ... wPost.aspx for more info). Another case was an ATI-card (again) that wouldn't honor Windows' desktop rotation settings in exclusive fullscreen mode. In theory the specs of the cards were well within Ventuz' requirements, in practice however...
sq.
