Maximum number of light sources
Kobbi
Post by Kobbi » 22 Jul 2016, 14:31
Hi Guys,
is there a maximum number of lights you can put in one Lightning group? Eight lights is maximum that works for me in V5.1.0. 9th and 10th source are not visible. 11th shows it self and kills light number one etc.
I need much more lights in one group in one of my scenes:(
Best,
Kobbi
Kobbi
Re: Maximum number of light sources
Post by Kobbi » 21 Nov 2016, 19:03
Hi guys,
I'm still experiencing this bug. I've attached a simple scene where you can see it does work as I've described in original post.
Best,
Kobbi
LightBug.vza
(15.48 KiB) Downloaded 502 times
lerou
Post by lerou » 22 Nov 2016, 09:14
The maximum is 8. I haven't seen anybody needing more than that. If you need more you should check your design and see if there's another way to achieve your goal (like textures or better grouping). You should also consider the performence.
Post by Karol » 22 Nov 2016, 17:29
Ventuz currently supports only 8 lights.
So the ninth light should disable the first.
This does not seem to work correctly - I created a Bug report for that.
