Copying/Pasting Container Content
Joe Styles
Post by Joe Styles » 05 Jul 2016, 11:45
There is a still a bug with pasting container content which was picked up in V4:
http://forum.ventuz.com/viewtopic.php?f=22&t=3704
Attached is a new scene that highlights this. If you make a change in Item1, copy it, select Item2 and "Paste Container Contents" it removes the Data Scheme for that item in the SceneData.
Is this on your fix list?
Thanks,
Joe
Joe Styles
Kinetic Pixel
Joe Styles
Re: Copying/Pasting Container Content
Post by Joe Styles » 05 Jul 2016, 11:46
helps if I attach the archive!
Container Items with scene data.vza
(132.04 KiB) Downloaded 436 times
Joe Styles
Kinetic Pixel
Götz_B
Post by Götz_B » 06 Jul 2016, 11:02
this is not a bug! It completely follows the logic of how "pasting container content" works.
You copy the content from one container to another. So if your nodes are connected to Scene Data Item1, then this is what you copy.
If you want to connect the properties to different Scene Data Channels, you have to expose them and bind them from the container to the Scene Data. As always with interface containers...
Götz
Joe Styles
Post by Joe Styles » 06 Jul 2016, 11:27
I see. That makes more logical sense build your interface and connect to the scene data. Then all the links are kept when you paste container content.
Just a new way of working rather using the old externals model ;)
Joe
Joe Styles
Kinetic Pixel
