Toch Button to freeze
Enchant2016
Post by Enchant2016 » 24 May 2016, 21:53
i´m a beginner and have a question:
I have a rectangle with material and a touch button. With a damper an the touch-button i turn the rectangle by transparency to invisible. But the rectangle will resist visible after press the button
It should not be visible. What can i do? I think with a expression-node, I don't know how to tackle it.
Can someone help me?
Thank you very much!
Uli
Re: Toch Button to freeze
Post by Karol » 25 May 2016, 16:20
Hi Uli!
Could you post your scene so that we can take a look on it?
Enchant2016
Post by Enchant2016 » 25 May 2016, 20:31
Hi Karol,
i post it at Monday, then I'm back in the agency.
Thank you!
uli
kberraho
Post by kberraho » 26 May 2016, 20:06
If I understand you correctly, you are trying to turn the visibility off of a rectangular when you click on it? Right?
If so, all you have to do is make sure you have the alpha value of the material node connected to the output of the damper, in the damper node, change the input 1 to 100, and input 2 to 0, and reduce the duration to something like 0.1s, and finally connect the use target2 to touch pressed of the touch button node. if you want it to stay( either invisible or visible after the click) then you might need to add a Toggle node in between the pressed node and the use target 2.
Hope this help. Enjoy
Enchant2016
Post by Enchant2016 » 30 May 2016, 08:39
Good Morning all,
thank you kberraho an karol for your help! The rectangle should become clear and the red cube then be moved. I do not know like with toggle works ;-(
here is my scene:
Thank you!
Uli
test 5.vzs
(11.09 KiB) Downloaded 516 times
stephan
Post by stephan » 31 May 2016, 07:11
Good morning Uli,
Ventuz offers millions of solutions for every task.
See attachment with toggle-node. Set invisibility to 0.001, my method for secure fade out. 0 is way with no return.
Cheers, Stephan
test 5_toggle.vzs
(11.04 KiB) Downloaded 568 times
Enchant2016
Post by Enchant2016 » 31 May 2016, 13:30
Hey Stephan,
thank you, this is great! Invisibility to 0.001 what I have made wrong. I set it to zero :roll:
I started to learn the tool and it is not so easy i think.
Uli ;)
stephan
Post by stephan » 02 Jun 2016, 07:45
Please be patient, don't give up. Ventuz is best presentation software this century :D
Post by Karol » 02 Jun 2016, 09:05
Hi Uli!
You don't need this 'hack' with the 0.001 Alpha Value!
In cases where a full transparent object should be validated anyway disable 'Block on full Transparency' in the AlphaFlags of the Material.
('Block on full Transparency' is usually a performance saver because the tree iteration stops there)
@stephan: Thank you!
stephan
Post by stephan » 02 Jun 2016, 09:52
@ Karol thanks for this hint ... never ending learning :D
