Template Layer when in a VPR
joysprod
Post by joysprod » 30 Mar 2016, 14:42
Unfortunately I cant get the Template Layer to work in the (F1) Examples so I'm having difficulty in trying to understand it.
I have a template layer that is loading a scene that has been made into a template. The data I am pasting into the 'Data' is
"@": "ventuz://templates/v5_touch%20scenes%7Cs1/Main/S2"
Works fine in Designer. Cant get the same when the Scene loader is made into a VPR and having a mental block as to why its not working.
Help Anyone?
Re: Template Layer when in a VPR
Post by chriss0212 » 30 Mar 2016, 15:36
hi peter,
don't know, if it helps in your case... but we normaly copy vprs into the project root. otherwise we have many problems with pathes... maybe same in this case.
next:
i normaly don't use a vpr anymore... if possible i start the project in "director mode".
joysprod
Post by joysprod » 30 Mar 2016, 17:44
Hi Chris,
Yes have tried the VPR at root and still no go.
Now have a further problem in that right-clicking on the project file does not give me an option to run as Director on this machine. Have Re-Installed V5 and removed V4 but still nothing. I dont know if this is a Registry problem?
joysprod
Post by joysprod » 30 Mar 2016, 18:07
Hi Chris, Have now got it working running in director mode. Unfortunately have found a bug with touches not being transmitted through the Template mode. Will post in the bug section.
Götz_B
Post by Götz_B » 31 Mar 2016, 09:31
Moin,
there was something with vpr and templates....
Please try to write your data string in lower case:
"@": "ventuz://templates/v5_touch%20scenes%7Cs1/main/s2"
Götz
joysprod
Post by joysprod » 01 Apr 2016, 14:20
Hi Götz
Have tried that and have now exhausted all possibilities of making this work - even as a very simple template and loader made into a VPR.
Change the template loader scene to default.vzs and running in Director mode works just fine. Bug?
Götz_B
Post by Götz_B » 04 Apr 2016, 09:13
No Bug.
I attached a vpa. Works fine. Even without setting everything to lower case.
Did you forget the Resource Linker?
TemplateLayer.vpa
(21.25 KiB) Downloaded 535 times
joysprod
Post by joysprod » 06 Apr 2016, 18:30
Ah Yes!
Looks like it was in twice! The one that had all the scenes ticked got deleted leaving an empty one that of course was doing nothing. So many places to hide nodes now!!
