Save text to CSV file
Post by Chris » 26 Mar 2016, 22:49
Hi All,
I have created a basic form to collect some text and save it out in CSV format.
I'm not the best in the world at scripting......so would someone mind having a quick look over my scene and letting me know if I can improve the script
in any way??
Is this the most efficient way to create as CSV file in Ventuz?
I also wanted to force some rules for the text that is entered in the boxes, i.e. not allowing the text to be added to the file unless a valid email address is entered.
Would anyone know how I can accomplish this??
The scene is pretty basic at this point, but any other suggestions on the scene as a whole are also more than welcome :D
Text to CSV.vza
(34.39 KiB) Downloaded 439 times
joschy
Re: Save text to CSV file
Post by joschy » 29 Mar 2016, 14:53
may be you already found this: https://social.msdn.microsoft.com/Forum ... m=netfxbcl
I can't load your file currently, it's PLE. Don't know how large your file is and there is a for loop, you should use the thread class https://msdn.microsoft.com/en-us/librar ... 71%29.aspx
Post by Chris » 29 Mar 2016, 21:59
Thanks for the reply joschy :)
Here's my code
//if file doesnt exist, create file
		if (!File.Exists(filePath))
			File.Create(filePath).Close();
		// Append line to the file.
		using (StreamWriter writer = new StreamWriter(filePath, true))
			writer.WriteLine(Data);
		changed = true;
It all works fine, just wondering if there is anything I should change to make it better??
