Hi Everyone,
This is a very URGENT issue i have to solve:
I am Using 2 BM Design Intensity (Pro in PciE and Shuttle as USB 3.0)
As i want signal from 2 Different PCs on and then Blend it on Ventuz.
I am Getting the signal Through the Shuttle USB 3.0 but not from the PCie, though both of them have the same settings (Format 1080i60) and the 2 PCs i am getting the signal are of the same resolution (1920 x 1080).
Hope you could Help me out as my Projects deployment is in 2 days.
Nik
(URGENT) Using 2 BlackMagic Intensity (Pro 4K and Shuttle)
nikulparekh90
- Dierk Ohlerich
Re: (URGENT) Using 2 BlackMagic Intensity (Pro 4K and Shuttl
Due to the large number of different Blackmagic products and high frequency of product updates, we can not test every Blackmagic product. The Intensity Pro 4k is a pretty new model and I never had one in my hand. We will try to get one and do some testing soon. Unfortunately this will take longer than two days.
Here are a few hints how to solve the problem without waiting for a possibly fixed Ventuz release:
* Switch of sync. Sync should only be switched on if the input source is genlocked to the output. I doubt this is the case, and even if it is you should try switching sync off just for testing.
* Make sure the input source is really 1080i59.94.
* Try to get an older board model. If you can get a decklink model, that would probably work better than an intensity model.
* the intensity 4k should work fine with 1080p59.94 / 1080p60. Try that.
-- Dierk Ohlerich
nikulparekh90
Hi Dierk
Thanks for the Reply.
Tried Everything but no luck. The project is over so its fine now.
If i Find something, i will post it here
