Hi there,
in V3 I can remember a setting where to choose the output device for the "designer fullscreen renderer", but in V4 I cannot find it... where is it or how can I change the fullscreen destination (more than 2 physical devices)?
Select output device for "Designer Fullscreen Renderer"
Re: Select output device for "Designer Fullscreen Renderer"
with V4 all those settings moved to the Configuration Editor. In the seconds section (Audio, Video and Hardware...) you can delete the current output and put in a new one. It will ask you which screen to use. Usually the numbers match those in the windows desktop settings... but not always. However you can use that to select the Display for Fullscreen in Designer mode as well as in Runtime mode.
Best,
Best,
errox
Hey rou,
thank you!!
Haven't really thought about removing the output device to have it just added again with a changed screen output....
Indeed the display numbers don't match.. but it works!
Regards!
thank you!!
Regards!
