valid image for texture
mixondigital
Hi all. Still a bit new to Ventuz4. I'm trying to build a scene that to display an image, that has a path coming from an excel spreadsheet. However, I might not have all of the images, so I want to use an alpha node to turn off a layer, if an image is not there. Tried using the Visuals Indexer node, but I don't think this is the right mode to achieve what I need. Any other suggestions?
Re: valid image for texture
Welcome to Ventuz
Put your file path through a url node. The node will give you a bool flag indicating whether the file exists. Use that to block your geometry.
cheers,
Welcome to Ventuz
cheers,
mixondigital
Thank you so much for the response. That worked!!! Appreciate the help!
Hi there,
Welcome to the ventuz forum.
A way I use a lot in V4 is the multiswitch node and use 2 texture properties. You can set them to FirstValid and connect your image to the first input and a transparent texture to the second.
Everytime the first texture is getting invalid it switches automatically to the second one.
Daniel
Daniel
