It seems that setting a rendersetup layout disable key+fill feature. This make impossible to use ventuz broadcast (key+fill) setup next to a normal setup within the same project.
Is it a bug or by design.
R
alpha background vs rendersetup
Re: alpha background vs rendersetup
its the Shaping and Warping that kills the key signal. It has a technical reason, so its not a bug.
By default the Shaping is enabled. To make the key work again, you can go to the Shaping (Top right corner in the Render Setup Editor) and disable the Warping completely (First three button on the top left in the Shaping Editor - Buttons 1,2,3 here: http://www.ventuz.com/support/help/late ... balToolbar
Hope that helps,
Götz
Hope that helps,
Götz
