Sometimes slicename property of "simple control" node are not available when this node is inside a nested scene.
The combobox doesn't want to open.
Nested animations are not correctly initialized when controled by a "simple control" node.
The animation jump from an arbitrary state.
R
Slicename in simple control node bug
Re: Slicename in simple control node bug
Do you mean that this happens if you open the nested scene via Scene Port.Robert wrote:Hi,
When does the jump happen? If you change the Progress property of the Simple Control node?Robert wrote:Hi,
Nested animations are not correctly initialized when controlled by a "simple control" node.
R
Demo scenes would be great!
Please see attached vza file.
- SliceNameListBug.vza
- (4.81 KiB) Downloaded 426 times
