hi all
have a sony vajo convertable laptop with windows 8 and a nvidia gt 735m. but in ventuz config editor i can only see the intel gpu. is this normal? and if...is ventuz using the nvidia?
performance ist very low end in this mode ;(
sony vajo
Re: sony vajo
Servus! You have to go into the nVidia display properties on the "Manage 3D Settings" page and open the "Program Settings" tab. Here you have to specifically choose the nVidia adapter for ventuz.exe and ventuzpresenter.exe. No more Intel.
Re: sony vajo
and servus zurueck
funny thing: this is what i have tried...nu success...
i changed it back to intel...and ventuz is still showing intel...but with much more power?!
but: dankeschoen
but: dankeschoen
Re: sony vajo
I got the same issue on my laptop at home as long as the nvidia is not in use the device is not enumarated by windows. The only way to work around is i.e to start Ventuz with the nvidia GPU(usually you can right click on the shortcut and say start with GPU....). With an application using the nvidia you can create a AVC where the nv card is listed.
Daniel
Daniel
Re: sony vajo
hi daniel,
it seems, that ventuz doesnt care of what is listed...and if adjusted it will play with the gpu what is anabled....so far the good point. but if i flip the screen to panel mode...it seems that the gpu is switching back to intel....do you have the same problem or any hint?
ths and greetz
ths and greetz
Re: sony vajo
On some mainoards / notebooks you can switch off the intel gpu inside the bios / uefi
Re: sony vajo
hi thomas
not in this case ;(
but thx for the hint. i haved disabled a vaio service and removed some magnets...no it seems to work....maybe it would work with the magnets....found the service later on...
not in this case ;(
