I want to use Ventuz API to do the snapshot with new thread. But when I see the Snapshot Method in Ventuz API there have a "Object asyncState".
I don't know how to define it. So is there any example to tell me how to define the asyncState?
Drac Zhang
About Ventuz API
Re: About Ventuz API
With Visual Basic, i used this code part :
As you can see, i'm not using the asyncState object "yop"
My skills are limited on API coding, but in my case i don't need this object
Hope it helps !
Dim yop As Object
returnedTaskTResult = clu(clustertoSnap).Snapshot(0, ImageFormat.PNG, 1920, 1080, Nothing, Nothing, Nothing, Nothing, Filter.High, True, yop)
Dim MS = New MemoryStream(returnedTaskTResult.Result)
PictureBox3.Image = Image.FromStream(MS)
Hope it helps !
Florian
Drac Zhang
Hi florian,
Thanks for answering my question. I will try it to see does it work.
Drac Zhang
Drac Zhang
