I'm trying to use a ShrinktFit node to be able to display any text of any length in a reserved space
The node allow me to define the space i want to allow but text is not warping itself
If i enable warp in sourcetext node, it will warp fin but the final sourcetext will be up/down sized to fit height ou width but the text won't warp the the true "right border"
Do i miss something ?
Thanks !
How to use ShrinktoFit node with warping
Re: How to use ShrinktoFit node with warping
Did you also set the width and height of the original block text node?
Yeah, I tried with and without SourceText Width / Height
I succeed only to get a sourcetext upsized/downsized but not able to get text wrap with the ShrinktoFit Node
Florian
