Hallo,
while importing an obj-geomtry i´ve got that popup:
" OBJ Import Error: Der Index war außerhalb des Arraybereichs"
Abhilfe möglich?
Gruss Marko
Fehlermeldung "Index Arraybereich..."
Re: Fehlermeldung "Index Arraybereich..."
hi marco
i am not sure but it seems that you have exported your model with features or values which are not supported in ventuz!
it could be that it is a problem of not baked/converted animation tags in c4d which I did not eliminate before exporting.
Can´t test it at the moment. I´ll give feed back after a new try. Thank to you both for the impulses.
cheers Marko
cheers Marko
