Please join our discord server HERE!! << click me![Very Happy :D](./images/smilies/icon_e_biggrin.gif)
videowalls controlled via touchtable
There is a project which has a 3*15videowalls, the videowalls need to be controlled via touchtable. The total resolution is 10-12K, plus many 3D models and 3D effect, so even if a set of high-end workstation is not enough, we may need a cluster machines, right? the configuration of clustering is not a big problem for me, but how to feed to videowalls and touchtable from a cluster simultaneously is my main concern.
Thanks in advance!
alfred
Thanks in advance!
alfred
Re: videowalls controlled via touchtable
I would like to add more information about this post, 1) the graphic on the touchtable is an abstraction of the one which is on the video walls due to the size is much different; 2)the resolution is 10K, that is to say, 10240*3072. Based on the information, my questions are: 1)how many workstations do I need if configured with ATI W8000? 2)Can I decrease the quantity by using DVI splitter or some hardware like that, if yes, can you give me some clue what brand and the model#; 3)is it necessary to configure a standalone workstation for touchtable, if yes, how to synchronize the cluster and the standalone workstation? using OSC node? if yes, can you explain the method in detail.
Thanks a lot!!!
alfred
Thanks a lot!!!
alfred
Hi Alfred,
What monitors are you using, and more important what is the native resolution of one monitor?
Those monitors are arranged in a 15 by 3 wall?
Is it really necessary to feed them with a native signal or could it be an option to combine some of them to a cluster and use an internal split functionality?
Tobi
Tobi
http://www.radar-touch.com
http://www.prime-touch.com
Hi Tobi,
I am not sure the brand, but the native resolution of each monitor is 1920*1080. They are arranged in 3*12(not 3*15, it's my fault
). Frankly speaking, I am not sure what resolution should be used. The distance between the video wall and the viewer is about 6-10 meters. Do you know how to calculate? What information do you need regarding to the needed resolution when calculation?
What is the native signal? how to combine the monitors to a cluster, and why? what is the internal split?
alfred
![Wink ;)](./images/smilies/icon_e_wink.gif)
alfred
Hi Alfred,
It might make sense for you to figure out the brand and monitor type and have a look in the manual.
Native resolution is physical resolution of the display. In your case native resolution of one display is 1920 by 1080.
Native resolution of the whole wall is 23040 by 3240. I think this too much for one PC.
usually those displays do have an internal split function. For example if you arrange them in a 3by3 cluster you can define which third of the whole image shall be displayed by which display.
What you could do is to create four 3by3 split groups. That would be an easy setup.
There are also other combinations possible, in the end it's a question how much money your customer wants top spend.
Tobi
Tobi
Hi Tobi,
The resolution I plan to use is 12288*2304, that is to say 1024*768 for each monitor. A high-end workstation equipped with ATI Firepro W9000, do you think one set workstation of this configuration is enough to process 12288*2304?
Internal split function, this is my first time to hear that. I draw a pic from what I understanding, pls check the attachement. Do I understand correctly?
In addition, can I use a videowalls processor, that is to say, 6 input(from W9000), 36 output to videowall, and the signal spans in a whole picture, with the resolution 12288-2304, is it possible or reasonable?
Cheers!
alfred
Cheers!
alfred
hi alfred
your sketch is ok but i think the maximum input resolution of a cluster lik this is 1920*1080 (maybe 1920*1200) what should be enough out of a distance from 6-10 meter!
your total resolution would be: 7680*1080 what is no a big problem....but depends on your show!
i already did a installation in china with a total resolution of 14400*1280 out of one box!
Hi Chris,
You said that the input resolution 1920*1080 or 1920*1200 is enough? Do you mean that resolution for a video wall of 3*12?
7680*1080, I was confused
how do you caculate this resolution?
14400*1280 out of one box is Okay? What kind of configuration does the workstation, can you listed in detail?
Cheers!
alfred
Cheers!
alfred
hi alfred
yes i mean 1920*1080 for each of the 4 clusters. you have 4 cluster 3*3 so you have a total resolution of 4*1920/1080 what is in total 7680**1080px
for 14400*1280 we used a high perf pc with a ati v9000 and 5 datapath x4. every display had a resolution of 1280*720 in portrait mode side by side! but at the end performance depends on your scene!
Christian is right regarding the clusters, that is what I would suggest as an easy solution with "ok" quality... But like I said, depends on what your customer wants to pay ![Smile :-)](./images/smilies/icon_e_smile.gif)
