Capturing video from web camera via Live video node, what kind of video card do you usually recommend? Decklink or Black Magic only? In addition, as far as I know, there are 8 devices available in the live video node, does it mean that video matrix should be used when go beyond 8,right? If yes, what brand and model do you use?
Cheers!
becckman
video capture
Re: video capture
Ive not used any blackmagic or decklink cards, but ive not heard the best reports about either. Deltacast is your best choice for use with Ventuz.
If you do want more than 8 live streams, yes you would need to use a matrix switcher to accomplish this. (unless someone knows something i dont
Also consider how many feeds you need on screen at the same time, if there is only ever 4 at one time say, then no need for more than four live streams
chris
chris
beckman david
Re: video capture
Hi Chris,
Thanks for your reply!
For Deltacast, which model do you recommend and how much is it in Euro? I can't find dealer of Deltacast in China.
How many video cards can one machine support simultaneously?
Beckman
Beckman
Re: video capture
hi david
as chriss said: best choice is deltacast! you can youse decklink, but this is not official supported by ventuz! next important question: how many live inputs do you want to show at the same time? and what is your input resolution?
if delay is important (live speach for eg) deltacast is the choice!
if you just need one or two live inputs at the same time, you should use a matrix switcher to switch between your sources!
Re: video capture
Backmagic cards are supported in Ventuz 4. Optimal are Deltacast or DVS.
As to how many we support - it depends on your hardware. SOoner or later, your bus will be overloaded, so that is usually the limitation. If you need FullHD, then probably 4-6 will be the upper limit. If you are at a lower res, then more will be possible.
beckman david
Re: video capture
Hi Christian,
As far as I know, blackmagic will be ok despite some frames delay for Ventuz3, right? It seems that Deltacast has no reseller in China. So....
Cheers!
Beckman
Cheers!
Beckman
beckman david
Re: video capture
Hi EricB,
There will not frame delay for Blackmagic in Ventuz4, right?
Cheers!
Beckman
Cheers!
Beckman
Re: video capture
Well, regardless of the card manufacturer or software, there will always be a frame delay, it is not physically possible to avoid it. (it requires at least one frame to read...)
