Render inside of a sphere
Is there a way to reverse normals so that I can render a texture on to the inside of a sphere? or do I need to do this in the 3D app?
Re: Render inside of a sphere
If already imported, add a RenderOptions node in front of your geometry and switch the Backface Culling to Clockwise/Counterclockwise. Otherwise you can change the orientation during the Import process as well.
