Animation deceleration and start again
PXLstar
Post by PXLstar » 04 Feb 2013, 14:36
Hi Guys,
Might be a simple one but I can't work this out at the moment.
If you have an animation ( or mover ) lets say 0 - 100 looped, and at any point you click & you wish to slowly decelerate to a stop and then on click again slowly accelerate to continue the loop, how do you do that ?
Colin
Re: Animation deceleration and start again
Post by chriss0212 » 04 Feb 2013, 15:28
you can place a damper behind your mover
chriss
PXLstar
Post by PXLstar » 04 Feb 2013, 15:44
Hi chriss,
I don't think that's going to do what i need,( I take it you mean just increase the duration to stop ). my animation needs to go from 0 - 100, 0 - 100, 0 -100 and I need to stop ( slowly ) at anywhere on that range and then continue from the stopped point ( slowly )
cheers
Colin
PXLstar
Post by PXLstar » 04 Feb 2013, 15:50
also needs to continue in the forward motion from the stopped point :)
PXLstar
Post by PXLstar » 04 Feb 2013, 17:17
A solution ( thanks for the hints Erik ) see attached VZA, although a bit messy if the object had to be on screen, visible, all of the time. ( maybe there is a better way of doing it ? )
STARTSTOP.vza
(7.31 KiB) Downloaded 508 times
Post by chriss0212 » 04 Feb 2013, 23:41
for me this works very well :-)
mover.vza
(4.55 KiB) Downloaded 554 times
Post by chriss0212 » 04 Feb 2013, 23:45
ah...sorry didnt get the thing with 0-100 without swing :-)
PXLstar
Post by PXLstar » 05 Feb 2013, 00:05
yeah needs to be without swing, would be good if there was a stop or pause with deceleration and acceleration function on the mover node :(
Post by chriss0212 » 05 Feb 2013, 00:22
maybe this works for you....and you can see....in ventuz you allways have many ways to get the goal :-)
mover2.vza
(5.02 KiB) Downloaded 521 times
PXLstar
Post by PXLstar » 05 Feb 2013, 22:48
Hi Chriss,
Yeah that would be it ! Nice ! a little simpler than mine :)
