Hello.
Working with shader editor, using a lot of shortcuts like ctrl-A, ctrl-V, ctrl-S, ctrl-X, supp, etc... causing some shortcuts not working, and at the end, the text in the shader disappears. Finally all the works is lost.
Shader editor
mofo7777
Re: Shader editor
Hello.
Nobody have problem with shader editor ?
I've got of problem with shortkey and i often loose my work. Especially with Ctrl-Z, it's not make Ctrl-Z in the shader, but in the IHM and so Ventuz return to an arbitrary old work. Very annoying.
