Hi there!
I am facing a strange thing about making a snapshots with a Snapshot node. If i want to make a screenshot in normal Ventuz mode it works pretty fine - the snapshot appears in the same resolution as the render window. My problem is that in fullscreen mode my snapshot appears blank (just a black texture) in the same resolution as the render window was before switching to fullscreen mode.
Snapshot resolution fails with Fullscreen.
Re: Snapshot resolution fails with Fullscreen.
Hmm seems to be weired.
Which fullscreen mode do you use? Exclusive or virtual fullscreen?
Check your project properties --> Direct3D-->Fullscreen and try it in virtual fullscreen mode.
Cheers!
Cheers!
